[postgis-users] distance() Unit's
Alex Mayrhofer axelm-postgis at nona.net
Mon Jan 9 00:47:31 PST 2006
Adam wrote:
> I'm finding all the cities within a certian distance using the DISTANCE
> function.
> What is the unit of measurement for the distance?
> Can it be set to miles or feet?
Hi Adam,
the units of the result are the units of the original data. If you are using
lat/lon data, the results will be in those "latlon" units (which means that
the actual distance will vary by latitude).
> I checked the documentation but didn't find anything.
> geo=# SELECT name FROM city_locations WHERE distance (the_geom, 'POINT(
> -88.0501 41.8616 )' ) < 0.1;
If you need "proper" distances you will either need to reproject the map
data from lat/lon, eg. into UTM. See the documentation about transform() on
how to do this.
Or: you may also want to look into the "distance_sphere()" and
"distance_spheroid()" functions - a query using this would probably look like
SELECT name, distance_sphere(the_geom, 'POINT(-88.0501 41.8616)') FROM
city_locations WHERE expand('POINT(-88.0501 41.8616)', 0.1) && the_geom AND
distance_sphere(the_geom, 'POINT(-88.0501 41.8616)') < 1000;
(disclaimer: untested - should return all cities less than 1000 meters from
the given POINT - you need to check the expand() distance for it's relations
to the maximum distance... This would also make use of on index over the_geom)
alex mayrhofer
