[postgis-users] Query planner problems
Don Drake don at drakeconsult.com
Mon Jan 9 12:32:00 PST 2006
Try recompiling the procedure, I believe the query plan is cached.
-Don
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Stephen
Woodbridge
Sent: Monday, January 09, 2006 2:27 PM
To: PostGIS Users Discussion
Subject: [postgis-users] Query planner problems
Hi all,
I'm trying to create a pgpsql function to spatially assign the nearest
city in a table to a point.
CREATE OR REPLACE
FUNCTION swoodbridge.get_closest_city(  public.geometry,   float8)
RETURNS int4 AS
$BODY$
   declare
     pnt   alias for $1;
     miles alias for $2;
     dist  float;
     cid   integer;
   begin
     if pnt is null then
       return 0;
     end if;
     dist = swoodbridge.miles_to_degree(miles, 0.0);
     select city_id into cid from swoodbridge.city t_in where
expand(pnt, dist) && t_in.the_geom
       order by distance_sphere(pnt, t_in.the_geom) asc limit 1;
     if not found then
       return 0;
     else
       return cid;
     end if;
   end;
$BODY$
LANGUAGE 'plpgsql' VOLATILE;
But it is working horridly slow. I extracted the select and just add
constants of "pnt" so I could run explain on it. I can not get it to use
the gist index on the table.
select city_id from swoodbridge.city t_in
   where t_in.the_geom && expand(setsrid(makepoint(0,0),4326), 10)
   order by distance_sphere(setsrid(makepoint(0,0),4326), t_in.the_geom)
     asc limit 1;
> Limit  (cost=166074.43..166074.43 rows=1 width=29)
>   ->  Sort  (cost=166074.43..166215.21 rows=56314 width=29)
>         Sort Key:
distance_sphere('0101000020E610000000000000000000000000000000000000'::geomet
ry, the_geom)
>         ->  Seq Scan on city t_in  (cost=0.00..160699.25 rows=56314
width=29)
>               Filter: (the_geom &&
'0103000020E6100000010000000500000000000000000024C000000000000024C0000000000
00024C0000000000000244000000000000024400000000000002440000000000000244000000
000000024C000000000000024C000000000000024C0'::geometry)
It has the following gist index and it has been vacuum analyzed.
CREATE INDEX city_gist ON swoodbridge.city USING btree (the_geom);
Is there some way to force it to use the index?
-Steve
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
