[postgis-users] SQL Statement for Multiple Tables - operator doesn't exist: boolean && geometry
Adam adam at spatialsystems.org
Wed Jan 11 22:39:08 PST 2006
I have three tables:  zip codes, metro areas, and states.
My sql statement is:
SELECT zipcodes.name, urban_areas.name, states.state FROM zipcodes,
urban_areas, states WHERE distance( zipcodes.the_geom, 'POINT(-88.0501
41.8623)') = 0 AND zipcodes.the_geom && urban_areas.the_geom &&
states.the_geom
When I try to query them all in one statement I get this error:
operator does not exist, boolean && geometry
Hint:  No operator matches the given name and argument type(s).  You may
need to add explicit type casts.
If I run this statement with only two tables instead of three this statement
will work.
How should I join three plus tables and query for one locaton?
