[postgis-users] Interpolate Point
strk at refractions.net strk at refractions.net
Thu Jan 12 03:12:52 PST 2006
In order to "explode" multi geometries you need to use the
dump(geometry) function. This would return a set of basic components
(POINT,LINE,POLYS). One you have these you can use distance()
to find the nearest line to your point. Then you proceed
with locate and interpolate.
--strk;
On Thu, Jan 12, 2006 at 09:04:47AM -0200, sergio at labtrans.ufsc.br wrote:
> Hello again,
>    My problem is the following one:  I need to interpolate a point with a
> line, being that for this I possess two tables, I was trying to use the
> following command:
>   - SELECT line_interpolate_point(f.geom, line_locate_point(f.geom,
> c.geom)) from railroad f, city c;
>   Where geom of the railroad is a field MULTILINESTRING and geom of the city
> is a field POINT, this command does not function, therefore the first
> argument of line_locate_point must be LINE and not MULTILINESTRING, would
> like to know if somebody possue some suggestion of as I can tranformar
> this MULTILINESTRING in LINE or if exists some function that finds the
> line next to a point and that it returns as resulted the point where the
> original point is interpolated with the line.
> grateful,
> Sérgio Zarth Jr.
> postgis-users mailing list
 /"\    ASCII Ribbon Campaign
 \ /    Respect for low technology.
  X     Keep e-mail messages readable by any computer system.
 / \    Keep it ASCII.
