[postgis-users] SQL Statement for Multiple Tables - operatordoesn't exist: boolean && geometry
Emily Gouge egouge at refractions.net
Thu Jan 12 08:32:59 PST 2006
Adam,
The '&&' operator compares the bounding boxes of the geometries, not the actual geometries.  Table
joins done using the '&&' operator will join any two rows where the bounding boxes of the geometries
overlap.  I'm not sure what the data looks like, however in addition to the && operator you might
need to add an intersects (or other geometry function) constraint to the join as well (so the
actually geometries are compared).  Something like "...zipcodes.the_geom && states.the_geom AND
intersects(zipcodes.the_geom, states.the_geom) ..."
Emily
Adam wrote:
> I changed my query to this:
> SELECT zipcodes.name, urban_areas.name, states.state,
> time_zones.gmt_offset, counties.county
> FROM zipcodes, urban_areas, states, time_zones, counties
> WHERE zipcodes.the_geom && urban_areas.the_geom AND
>              zipcodes.the_geom && time_zones.the_geom AND
>              zipcodes.the_geom && counties.the_geom
> AND distance( zipcodes.the_geom, 'POINT(-88.050121 41.862380)') = 0
> When it runs I get multiple rows with states and counties way off point.  \
> The output should look like:  60137, Chicago Metro Area, Illinois, -6,
> DuPage County
> But here's my output:
> 60137, Chicago Metro Area, Michigan, -6,
> 60137, Chicago Metro Area, Michigan, -6, Cook County
> 60137, Chicago Metro Area, Michigan, -6, DuPage County
> 60137, Chicago Metro Area, Illinois, -6, Cook County
> 60137, Chicago Metro Area, Illinois, -6, DuPage County
> 60137, Chicago Metro Area, Michigan, -5,
> 60137, Chicago Metro Area, Michigan, -5, Cook County
> 60137, Chicago Metro Area, Michigan, -5, DuPage County
> 60137, Chicago Metro Area, Illinois, -5,
> 60137, Chicago Metro Area, Illinois, -5, Cook County
> 60137, Chicago Metro Area, Illinois, -5, DuPage County
> What am I doing wrong with this query?
> ----- Original Message ----- From: "Paul Ramsey" <pramsey at refractions.net>
> To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
> Sent: Thursday, January 12, 2006 12:50 AM
> Subject: Re: [postgis-users] SQL Statement for Multiple Tables -
>> Just add an "and":
>> WHERE distance( zipcodes.the_geom, 'POINT(-88.0501 41.8623)') = 0 AND
>> AND zipcodes.the_geom && states.the_geom
>> On Jan 11, 2006, at 10:39 PM, Adam wrote:
>>> I have three tables:  zip codes, metro areas, and states.
>>> My sql statement is:
>>> SELECT zipcodes.name, urban_areas.name, states.state FROM zipcodes,
>>> urban_areas, states WHERE distance( zipcodes.the_geom, 'POINT
>>> (-88.0501 41.8623)') = 0 AND zipcodes.the_geom &&
>>> urban_areas.the_geom && states.the_geom
>>> When I try to query them all in one statement I get this error:
>>> operator does not exist, boolean && geometry
>>> Hint:  No operator matches the given name and argument type(s).   You
>>> may need to add explicit type casts.
>>> If I run this statement with only two tables instead of three this
>>> statement will work.
>>> How should I join three plus tables and query for one locaton?
>>> postgis-users mailing list
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
