[postgis-users] postgis_restore.pl loads no data (pg-8.1, postgis-1.1)
strk at refractions.net strk at refractions.net
Fri Jan 13 00:47:18 PST 2006
Please give postgis_restore.pl a try and let use know.
--strk;
On Thu, Jan 12, 2006 at 07:50:19PM +0100, Benjamin Thelen wrote:
> Hi list,
> I backed up a postgresql/postgis DB from a
> postgresql-8.0.4/postgis-1.0.4 combination and tried to restore the dump
> into a 8.1.2/1.1.0 combination and failed. It seems that all
> (functions,..) but the data itself is uploaded. The procedure just stops
> as it seems without any error message. Please have a look at the end of
> the output below.
> The most interesting part is that I also tried to upload the same dump
> into the same DB but using an old postgis_restore.pl from postgis-1.0.4
> and succeeded! At least it seems at first glance. In this case the
> output doesn't stop as you see below, but continues to load the data
> itself into the database.
> I couldn't find anything on the internet, just the information, that
> postgis itself is pg-8.1 compatible and postgis_restore.pl hasn't
> officially been testet with this pg version.
> I'm a bit at a loss. Do I have to go back to 8.0? Is there something
> I've overlooked, I can do?
> Thanks,
> Ben
> LANGUAGE 'plpgsql' IMMUTABLE STRICT;
> CREATE FUNCTION
> -- SFSQL 1.1
> -- BdMPolyFromText(multiLineStringTaggedText String, SRID Integer):
> MultiPolygon
> --  Construct a MultiPolygon given an arbitrary
> --  collection of closed linestrings as a
> --  MultiLineString text representation.
> -- This is a PLPGSQL function rather then an SQL function
> -- To raise an exception in case of invalid input.
> CREATE OR REPLACE FUNCTION BdMPolyFromText(text, integer)
> RETURNS geometry
> AS '
> DECLARE
> 	geomtext alias for $1;
> 	srid alias for $2;
> 	mline geometry;
> 	geom geometry;
> BEGIN
> 	mline := MultiLineStringFromText(geomtext, srid);
> 	IF mline IS NULL
> 	THEN
> 		RAISE EXCEPTION ''Input is not a MultiLinestring'';
> 	END IF;
> 	geom := multi(BuildArea(mline));
> 	RETURN geom;
> END;
> CREATE FUNCTION
> -- END
> COMMIT;
> COMMIT
> DROP TABLE geometry_columns;DROP TABLE spatial_ref_sys;
> DROP TABLE
> DROP TABLE
> postgis-users mailing list
 /"\    ASCII Ribbon Campaign
 \ /    Respect for low technology.
  X     Keep e-mail messages readable by any computer system.
 / \    Keep it ASCII.
