[postgis-users] Moving point grid
Maik Trömel maik.troemel at maitro.net
Fri Jan 13 05:55:20 PST 2006
Hello again,
I'm trying to run the following command:
nsumm=# UPDATE geom_pgsql_summe SET
the_geom=transform(translate(transform (SetSRID(the_geom, 4326), 32632),
13000, 13000), 4326);
ERROR:  new row for relation "geom_pgsql_summe" violates check
constraint "enforce_srid_the_geom"
nsumm=#
I don't understand whats wrong.
Thanks for your help
Greetings
Maik
Guido Lemoine wrote:
> transform your points to a UTM projection (e.g. SRID=32632 for UTM
> Zone 32 N,
> hopefully, they're all in one zone), then translate -13000, -13000 and
> transform back
> to SRID=4326.
> select astext(transform(translate(transform(SetSRID(Makepoint(9.0,
> 45.0), 4326), 32632), -13000, -13000), 4326));
> yields POINT(8.83539247380864 44.88285511722)
> GL
> Maik Trömel wrote:
>> Hi,
>> i want to translate a dataset with a point grid 13 km into the west
>> and 13 km into the south. The problem is that the points coordinates
>> are in lat/lon. How can I move them in km?
>> Thanks fpr your help!
>> Greetings
>> Maik
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
