[postgis-users] postgis installation on current Postgresql (8.1) database (on Debian)
alex bodnaru alexbodn at 012.net.il
Sun Jan 15 19:30:09 PST 2006
hi steve,
happy to hear you are using my software.
would you please be more specific on the fixes you needed? (i might do
it for all).
please be also specific on the debian version you use.
alex
On Sun, 2006-01-15 at 21:58 -0500, Stephen Woodbridge wrote:
> Hi Alex,
> Your patch and process works, but has a minor bug in it. You need to fix
> the package dependencies. You have listed all the *-dev packages
> separated with commas ',' instead of pipes '|' once I fixed that is
> compiled and installed fine on Debian sarge amd64 platform.
> -Steve
> > Hi Alex,
> > I am running a debian sarge amd64 system and have grabbed the sid source
> > for postgresql and build it. Is there a package for postGIS-1.1.0 that I
> > can download and build for dpkg?
> > It looks like I might be able to follow the pocedure your listed below.
> > Is this correct? I have the patch file you posted before.
> > Thanks,
> >   -Steve
> > alex bodnaru wrote:
> >> assad,
> >> your ./configure output seems a little wird for a clean postgresql sarge
> >> installation.
> >> the procedure below will possibly help. if still in problem, you might
> >> need to have a better backported postgresql for sarge, or upgrade debian.
> >> please apply this diff to the *clean* postgis source:
> >> cd postgis_source_root
> >> zcat the_attached_file | patch -p1
> >> # you should have ./debian subdirectory in postgis_source_root
> >> chmod ug+x debian/rules
> >> dpkg-buildpackage -rfakeroot
> >> good luck,
> >> alex
> >> Assad Jarrahian wrote:
> >>> Alex,
> >>>  I am running sarge. How do I get a hold of that package.
> >>> I looked at
> >>> http://pkg-grass.alioth.debian.org/cgi-bin/wiki.pl/PackageList
> >>> and it says postgis (now uninstallable)
> >>> thanks for your help alex.
> >>> -assad
> >>> On 1/13/06, alex bodnaru <alexbodn at 012.net.il> wrote:
> >>>> what debian version do you have?
> >>>>> I took a closer look. The directory /usr/include/postgresql/ exists
> >>>>> and postgres.h is in that directory.
> >>>>> There is no 8.1 directory.
> >>>>> How do I mend the problem (tell pg-config that the directory is
> >>>>> somewhere else)
> >>>>> much thanks and sorry for the initial lookover of the file existing.
> >>>>> -assad
> >>>>> On 1/13/06, strk at refractions.net <strk at refractions.net> wrote:
> >>>>>> This is your problem:
> >>>>>> gcc -DUSE_VERSION=81 -DPOSTGIS_LIB_VERSION='"1.1.0"'
> >>>>>> -DPOSTGIS_VERSION='"1.1 USE_GEOS=1 USE_PROJ=1 USE_STATS=1"'
> >>>>>> -DPOSTGIS_SCRIPTS_VERSION='"1.1.0"' -DPOSTGIS_BUILD_DATE='"2006-01-12
> >>>>>> 16:30:40"' -I/usr/local/include -DUSE_PROJ
> >>>>>> -I/usr/include/postgresql/8.1/server -DAUTOCACHE_BBOX=1  -DUSE_STATS
> >>>>>> -Wall -g -O2 -fPIC -fexceptions -DUSE_GEOS
> >>>>>> -I/usr/local/include     -c
> >>>>>> -o liblwgeom.o liblwgeom.c
> >>>>>> In file included from liblwgeom.c:26:
> >>>>>> lwgeom_pg.h:4:22: error: postgres.h: No such file or directory
> >>>>>> Do you stil confirm that this file exist:
> >>>>>>      /usr/include/postgresql/8.1/server/postgres.h
> >>>>>> --strk;
> >>>>>> On Fri, Jan 13, 2006 at 01:15:45AM -0700, Assad Jarrahian wrote:
> >>>>>>> strk, stefano, david .... please help. Am stuck.
> >>>>>>> Thanks.
> >>>>>>> -assad
> >>>>>>> On 1/12/06, Assad Jarrahian <jarraa at gmail.com> wrote:
> >>>>>>>> I pasted the complete output below. Thanks for your help.
> >>>>>>>> make -C lwgeom
> >>>>>>>> make[1]: Entering directory `/packages/postgis-1.1.0/lwgeom'
> >>>>>>>> cpp -P -traditional-cpp -DUSE_VERSION=81 lwpostgis.sql.in | sed -e
> >>>>>>>> 's:@MODULE_FILENAME@:\$libdir/liblwgeom.so.1.1:g;s:@POSTGIS_VERSION@:1.1
> >>>>>>>> USE_STATS=1:g;s:@POSTGIS_SCRIPTS_VERSION@:1.1.0:g;s/@POSTGIS_BUILD_DATE@/2006-01-12
> >>>>>>>> 16:30:40/g' | grep -v '^#' > ../lwpostgis.sql
> >>>>>>>> /usr/bin/perl ../utils/postgis_proc_upgrade.pl ../lwpostgis.sql >
> >>>>>>>> ../lwpostgis_upgrade.sql
> >>>>>>>> -DUSE_STATS
> >>>>>>>> -o measures.o measures.c
> >>>>>>>> -DUSE_STATS
> >>>>>>>> -o box2d.o box2d.c
> >>>>>>>> -DUSE_STATS
> >>>>>>>> -o ptarray.o ptarray.c
> >>>>>>>> ptarray.c: In function 'ptarray_segmentize2d':
> >>>>>>>> ptarray.c:223: warning: dereferencing type-punned pointer will
> >>>>>>>> break
> >>>>>>>> strict-aliasing rules
> >>>>>>>> break
> >>>>>>>> -DUSE_STATS
> >>>>>>>> -o lwgeom_api.o lwgeom_api.c
> >>>>>>>> lwgeom_api.c: In function 'lwgeom_getpoint_inspected':
> >>>>>>>> lwgeom_api.c:974: warning: pointer targets in assignment differ
> >>>>>>>> in signedness
> >>>>>>>> lwgeom_api.c:981: warning: pointer targets in passing argument 1 of
> >>>>>>>> 'lwpoint_deserialize' differ in signedness
> >>>>>>>> lwgeom_api.c: In function 'lwgeom_getpoly':
> >>>>>>>> lwgeom_api.c:1051: warning: pointer targets in assignment differ
> >>>>>>>> in signedness
> >>>>>>>> lwgeom_api.c:1057: warning: pointer targets in passing argument
> >>>>>>>> 1 of
> >>>>>>>> 'lwpoly_deserialize' differ in signedness
> >>>>>>>> lwgeom_api.c: In function 'lwgeom_getpoly_inspected':
> >>>>>>>> lwgeom_api.c:1069: warning: pointer targets in assignment differ
> >>>>>>>> in signedness
> >>>>>>>> lwgeom_api.c:1076: warning: pointer targets in passing argument
> >>>>>>>> 1 of
> >>>>>>>> lwgeom_api.c: In function 'lwgeom_getsubgeometry':
> >>>>>>>> lwgeom_api.c:1097: warning: pointer targets in assignment differ
> >>>>>>>> in signedness
> >>>>>>>> lwgeom_api.c:1099: warning: pointer targets in return differ in
> >>>>>>>> signedness
> >>>>>>>> lwgeom_api.c: In function 'printPA':
> >>>>>>>> lwgeom_api.c:1636: warning: pointer targets in assignment differ
> >>>>>>>> in signedness
> >>>>>>>> lwgeom_api.c:1637: warning: pointer targets in assignment differ
> >>>>>>>> in signedness
> >>>>>>>> lwgeom_api.c: In function 'printBYTES':
> >>>>>>>> lwgeom_api.c:1674: warning: pointer targets in passing argument
> >>>>>>>> 2 of
> >>>>>>>> 'deparse_hex' differ in signedness
> >>>>>>>> lwgeom_api.c: In function 'pglwgeom_from_ewkb':
> >>>>>>>> lwgeom_api.c:1775: warning: pointer targets in passing argument
> >>>>>>>> 2 of
> >>>>>>>> lwgeom_api.c: In function 'lwgeom_typeflags':
> >>>>>>>> lwgeom_api.c:2000: warning: pointer targets in return differ in
> >>>>>>>> signedness
> >>>>>>>> lwgeom_api.c: In function 'parse_lwgeom_wkt':
> >>>>>>>> lwgeom_api.c:2242: warning: pointer targets in passing argument
> >>>>>>>> 1 of
> >>>>>>>> 'parse_lwg' differ in signedness
> >>>>>>>> lwgeom_api.c: In function 'box2df_to_box3d':
> >>>>>>>> lwgeom_api.c:220: warning: 'result.zmin' is used uninitialized
> >>>>>>>> in this function
> >>>>>>>> lwgeom_api.c:220: warning: 'result.zmax' is used uninitialized
> >>>>>>>> in this function
> >>>>>>>> lwgeom_api.c:220: warning: 'result.ymax' is used uninitialized
> >>>>>>>> in this function
> >>>>>>>> lwgeom_api.c:220: warning: 'result.xmax' is used uninitialized
> >>>>>>>> in this function
> >>>>>>>> lwgeom_api.c:220: warning: 'result.ymin' is used uninitialized
> >>>>>>>> in this function
> >>>>>>>> lwgeom_api.c:220: warning: 'result.xmin' is used uninitialized
> >>>>>>>> in this function
> >>>>>>>> -DUSE_STATS
> >>>>>>>> -o lwgeom.o lwgeom.c
> >>>>>>>> lwgeom.c: In function 'lwgeom_to_ewkb':
> >>>>>>>> lwgeom.c:409: warning: pointer targets in return differ in
> >>>>>>>> signedness
> >>>>>>>> -DUSE_STATS
> >>>>>>>> -o lwpoint.o lwpoint.c
> >>>>>>>> -DUSE_STATS
> >>>>>>>> -o lwline.o lwline.c
> >>>>>>>> -DUSE_STATS
> >>>>>>>> -o lwpoly.o lwpoly.c
> >>>>>>>> lwpoly.c: In function 'lwpoly_deserialize':
> >>>>>>>> lwpoly.c:80: warning: pointer targets in assignment differ in
> >>>>>>>> signedness
> >>>>>>>> lwpoly.c:90: warning: pointer targets in assignment differ in
> >>>>>>>> signedness
> >>>>>>>> lwpoly.c:105: warning: pointer targets in passing argument 1 of
> >>>>>>>> 'get_int32' differ in signedness
> >>>>>>>> lwpoly.c:113: warning: pointer targets in passing argument 1 of
> >>>>>>>> 'get_uint32' differ in signedness
> >>>>>>>> lwpoly.c:121: warning: pointer targets in passing argument 1 of
> >>>>>>>> lwpoly.c:124: warning: pointer targets in passing argument 1 of
> >>>>>>>> 'pointArray_construct' differ in signedness
> >>>>>>>> -DUSE_STATS
> >>>>>>>> -o lwmpoint.o lwmpoint.c
> >>>>>>>> -DUSE_STATS
> >>>>>>>> -o lwmline.o lwmline.c
> >>>>>>>> -DUSE_STATS
> >>>>>>>> -o lwmpoly.o lwmpoly.c
> >>>>>>>> -DUSE_STATS
> >>>>>>>> -o lwcollection.o lwcollection.c
> >>>>>>>> -DUSE_STATS
> >>>>>>>> -o wktunparse.o wktunparse.c
> >>>>>>>> -DUSE_STATS
> >>>>>>>> -o lwgparse.o lwgparse.c
> >>>>>>>> -DUSE_STATS
> >>>>>>>> -o wktparse.tab.o wktparse.tab.c
> >>>>>>>> wktparse.y: In function 'lwg_parse_yyparse':
> >>>>>>>> wktparse.y:43: warning: pointer targets in passing argument 1 of
> >>>>>>>> 'alloc_wkb' differ in signedness
> >>>>>>>> -DUSE_STATS
> >>>>>>>> -o lex.yy.o lex.yy.c
> >>>>>>>> lex.yy.c:3044: warning: 'yyunput' defined but not used
> >>>>>>>> -DUSE_STATS
> >>>>>>>> -o vsprintf.o vsprintf.c
> >>>>>>>> -DUSE_STATS
> >>>>>>>> lwgeom_pg.h:5:29: error: utils/geo_decls.h: No such file or
> >>>>>>>> directory
> >>>>>>>> lwgeom_pg.h:6:18: error: fmgr.h: No such file or directory
> >>>>>>>> lwgeom_pg.h:28: error: syntax error before 'getGeometryOID'
> >>>>>>>> lwgeom_pg.h:28: warning: type defaults to 'int' in declaration of
> >>>>>>>> 'getGeometryOID'
> >>>>>>>> lwgeom_pg.h:28: warning: data definition has no type or storage
> >>>>>>>> class
> >>>>>>>> lwgeom_pg.h:35: error: syntax error before '*' token
> >>>>>>>> lwgeom_pg.h:36: error: syntax error before 'box2df_to_box'
> >>>>>>>> lwgeom_pg.h:36: warning: type defaults to 'int' in declaration of
> >>>>>>>> 'box2df_to_box'
> >>>>>>>> lwgeom_pg.h:36: warning: data definition has no type or storage
> >>>>>>>> class
> >>>>>>>> lwgeom_pg.h:37: error: syntax error before 'BOX'
> >>>>>>>> lwgeom_pg.h:40: error: syntax error before 'BOX2D_same'
> >>>>>>>> lwgeom_pg.h:40: warning: type defaults to 'int' in declaration
> >>>>>>>> of 'BOX2D_same'
> >>>>>>>> lwgeom_pg.h:40: warning: parameter names (without types) in
> >>>>>>>> function declaration
> >>>>>>>> lwgeom_pg.h:40: warning: data definition has no type or storage
> >>>>>>>> class
> >>>>>>>> lwgeom_pg.h:41: error: syntax error before 'BOX2D_overlap'
> >>>>>>>> lwgeom_pg.h:41: warning: type defaults to 'int' in declaration of
> >>>>>>>> 'BOX2D_overlap'
> >>>>>>>> lwgeom_pg.h:41: warning: parameter names (without types) in
> >>>>>>>> lwgeom_pg.h:41: warning: data definition has no type or storage
> >>>>>>>> class
> >>>>>>>> lwgeom_pg.h:42: error: syntax error before 'BOX2D_overleft'
> >>>>>>>> lwgeom_pg.h:42: warning: type defaults to 'int' in declaration of
> >>>>>>>> 'BOX2D_overleft'
> >>>>>>>> lwgeom_pg.h:42: warning: parameter names (without types) in
> >>>>>>>> lwgeom_pg.h:42: warning: data definition has no type or storage
> >>>>>>>> class
> >>>>>>>> lwgeom_pg.h:43: error: syntax error before 'BOX2D_left'
> >>>>>>>> lwgeom_pg.h:43: warning: type defaults to 'int' in declaration
> >>>>>>>> of 'BOX2D_left'
> >>>>>>>> lwgeom_pg.h:43: warning: parameter names (without types) in
> >>>>>>>> lwgeom_pg.h:43: warning: data definition has no type or storage
> >>>>>>>> class
> >>>>>>>> lwgeom_pg.h:44: warning: type defaults to 'int' in declaration
> >>>>>>>> of 'BOX2D_right'
> >>>>>>>> lwgeom_pg.h:44: warning: parameter names (without types) in
> >>>>>>>> lwgeom_pg.h:44: warning: data definition has no type or storage
> >>>>>>>> class
> >>>>>>>> lwgeom_pg.h:45: error: syntax error before 'BOX2D_overright'
> >>>>>>>> lwgeom_pg.h:45: warning: type defaults to 'int' in declaration of
> >>>>>>>> 'BOX2D_overright'
> >>>>>>>> lwgeom_pg.h:45: warning: parameter names (without types) in
> >>>>>>>> lwgeom_pg.h:45: warning: data definition has no type or storage
> >>>>>>>> class
> >>>>>>>> lwgeom_pg.h:46: error: syntax error before 'BOX2D_overbelow'
> >>>>>>>> lwgeom_pg.h:46: warning: type defaults to 'int' in declaration of
> >>>>>>>> 'BOX2D_overbelow'
> >>>>>>>> lwgeom_pg.h:46: warning: parameter names (without types) in
> >>>>>>>> lwgeom_pg.h:46: warning: data definition has no type or storage
> >>>>>>>> class
> >>>>>>>> lwgeom_pg.h:47: error: syntax error before 'BOX2D_below'
> >>>>>>>> lwgeom_pg.h:47: warning: type defaults to 'int' in declaration
> >>>>>>>> of 'BOX2D_below'
> >>>>>>>> lwgeom_pg.h:47: warning: parameter names (without types) in
> >>>>>>>> lwgeom_pg.h:47: warning: data definition has no type or storage
> >>>>>>>> class
> >>>>>>>> lwgeom_pg.h:48: error: syntax error before 'BOX2D_above'
> >>>>>>>> lwgeom_pg.h:48: warning: type defaults to 'int' in declaration
> >>>>>>>> of 'BOX2D_above'
> >>>>>>>> lwgeom_pg.h:48: warning: parameter names (without types) in
> >>>>>>>> lwgeom_pg.h:48: warning: data definition has no type or storage
> >>>>>>>> class
> >>>>>>>> lwgeom_pg.h:49: error: syntax error before 'BOX2D_overabove'
> >>>>>>>> lwgeom_pg.h:49: warning: type defaults to 'int' in declaration of
> >>>>>>>> 'BOX2D_overabove'
> >>>>>>>> lwgeom_pg.h:49: warning: parameter names (without types) in
> >>>>>>>> lwgeom_pg.h:49: warning: data definition has no type or storage
> >>>>>>>> class
> >>>>>>>> lwgeom_pg.h:50: error: syntax error before 'BOX2D_contained'
> >>>>>>>> lwgeom_pg.h:50: warning: type defaults to 'int' in declaration of
> >>>>>>>> 'BOX2D_contained'
> >>>>>>>> lwgeom_pg.h:50: warning: parameter names (without types) in
> >>>>>>>> lwgeom_pg.h:50: warning: data definition has no type or storage
> >>>>>>>> class
> >>>>>>>> lwgeom_pg.h:51: error: syntax error before 'BOX2D_contain'
> >>>>>>>> lwgeom_pg.h:51: warning: type defaults to 'int' in declaration of
> >>>>>>>> 'BOX2D_contain'
> >>>>>>>> lwgeom_pg.h:51: warning: parameter names (without types) in
> >>>>>>>> lwgeom_pg.h:51: warning: data definition has no type or storage
> >>>>>>>> class
> >>>>>>>> lwgeom_pg.h:52: error: syntax error before 'BOX2D_intersects'
> >>>>>>>> lwgeom_pg.h:52: warning: type defaults to 'int' in declaration of
> >>>>>>>> 'BOX2D_intersects'
> >>>>>>>> lwgeom_pg.h:52: warning: parameter names (without types) in
> >>>>>>>> lwgeom_pg.h:52: warning: data definition has no type or storage
> >>>>>>>> class
> >>>>>>>> lwgeom_pg.h:53: error: syntax error before 'BOX2D_union'
> >>>>>>>> lwgeom_pg.h:53: warning: type defaults to 'int' in declaration
> >>>>>>>> of 'BOX2D_union'
> >>>>>>>> lwgeom_pg.h:53: warning: parameter names (without types) in
> >>>>>>>> lwgeom_pg.h:53: warning: data definition has no type or storage
> >>>>>>>> class
> >>>>>>>> lwgeom_pg.h:55: error: syntax error before 'LWGEOM_same'
> >>>>>>>> lwgeom_pg.h:55: warning: type defaults to 'int' in declaration
> >>>>>>>> of 'LWGEOM_same'
> >>>>>>>> lwgeom_pg.h:55: warning: parameter names (without types) in
> >>>>>>>> lwgeom_pg.h:55: warning: data definition has no type or storage
> >>>>>>>> class
> >>>>>>>> lwgeom_pg.h:56: error: syntax error before 'BOX3D_construct'
> >>>>>>>> lwgeom_pg.h:56: warning: type defaults to 'int' in declaration of
> >>>>>>>> 'BOX3D_construct'
> >>>>>>>> lwgeom_pg.h:56: warning: parameter names (without types) in
> >>>>>>>> lwgeom_pg.h:56: warning: data definition has no type or storage
> >>>>>>>> class
> >>>>>>>> lwgeom_pg.h:57: error: syntax error before 'BOX2DFLOAT4_ymin'
> >>>>>>>> lwgeom_pg.h:57: warning: type defaults to 'int' in declaration of
> >>>>>>>> 'BOX2DFLOAT4_ymin'
> >>>>>>>> lwgeom_pg.h:57: warning: parameter names (without types) in
> >>>>>>>> lwgeom_pg.h:57: warning: data definition has no type or storage
> >>>>>>>> class
> >>>>>>>> lwgeom_pg.h:59: error: syntax error before 'LWGEOM_force_2d'
> >>>>>>>> lwgeom_pg.h:59: warning: type defaults to 'int' in declaration of
> >>>>>>>> 'LWGEOM_force_2d'
> >>>>>>>> lwgeom_pg.h:59: warning: parameter names (without types) in
> >>>>>>>> lwgeom_pg.h:59: warning: data definition has no type or storage
> >>>>>>>> class
> >>>>>>>> lwgeom_pg.h:60: error: syntax error before 'LWGEOM_force_3dm'
> >>>>>>>> lwgeom_pg.h:60: warning: type defaults to 'int' in declaration of
> >>>>>>>> 'LWGEOM_force_3dm'
> >>>>>>>> lwgeom_pg.h:60: warning: parameter names (without types) in
> >>>>>>>> lwgeom_pg.h:60: warning: data definition has no type or storage
> >>>>>>>> class
> >>>>>>>> lwgeom_pg.h:61: error: syntax error before 'LWGEOM_force_3dz'
> >>>>>>>> lwgeom_pg.h:61: warning: type defaults to 'int' in declaration of
> >>>>>>>> 'LWGEOM_force_3dz'
> >>>>>>>> lwgeom_pg.h:61: warning: parameter names (without types) in
> >>>>>>>> lwgeom_pg.h:61: warning: data definition has no type or storage
> >>>>>>>> class
> >>>>>>>> lwgeom_pg.h:62: error: syntax error before 'LWGEOM_force_4d'
> >>>>>>>> lwgeom_pg.h:62: warning: data definition has no type or storage
> >>>>>>>> class
> >>>>>>>> lwgeom_pg.h:63: error: syntax error before
> >>>>>>>> 'LWGEOM_force_collection'
> >>>>>>>> lwgeom_pg.h:63: warning: type defaults to 'int' in declaration of
> >>>>>>>> lwgeom_pg.h:63: warning: parameter names (without types) in
> >>>>>>>> lwgeom_pg.h:63: warning: data definition has no type or storage
> >>>>>>>> class
> >>>>>>>> lwgeom_pg.h:64: error: syntax error before 'LWGEOM_force_multi'
> >>>>>>>> lwgeom_pg.h:64: warning: type defaults to 'int' in declaration of
> >>>>>>>> lwgeom_pg.h:64: warning: parameter names (without types) in
> >>>>>>>> lwgeom_pg.h:64: warning: data definition has no type or storage
> >>>>>>>> class
> >>>>>>>> lwgeom_pg.h:66: error: syntax error before 'LWGEOMFromWKB'
> >>>>>>>> lwgeom_pg.h:66: warning: type defaults to 'int' in declaration of
> >>>>>>>> 'LWGEOMFromWKB'
> >>>>>>>> lwgeom_pg.h:66: warning: parameter names (without types) in
> >>>>>>>> lwgeom_pg.h:66: warning: data definition has no type or storage
> >>>>>>>> class
> >>>>>>>> lwgeom_pg.h:67: error: syntax error before 'WKBFromLWGEOM'
> >>>>>>>> lwgeom_pg.h:67: warning: type defaults to 'int' in declaration of
> >>>>>>>> 'WKBFromLWGEOM'
> >>>>>>>> lwgeom_pg.h:67: warning: parameter names (without types) in
> >>>>>>>> lwgeom_pg.h:67: warning: data definition has no type or storage
> >>>>>>>> class
> >>>>>>>> lwgeom_pg.h:69: error: syntax error before 'LWGEOM_getBBOX'
> >>>>>>>> lwgeom_pg.h:69: warning: type defaults to 'int' in declaration of
> >>>>>>>> 'LWGEOM_getBBOX'
> >>>>>>>> lwgeom_pg.h:69: warning: parameter names (without types) in
> >>>>>>>> lwgeom_pg.h:69: warning: data definition has no type or storage
> >>>>>>>> class
> >>>>>>>> lwgeom_pg.h:70: error: syntax error before 'LWGEOM_addBBOX'
> >>>>>>>> lwgeom_pg.h:70: warning: type defaults to 'int' in declaration of
> >>>>>>>> 'LWGEOM_addBBOX'
> >>>>>>>> lwgeom_pg.h:70: warning: parameter names (without types) in
> >>>>>>>> lwgeom_pg.h:70: warning: data definition has no type or storage
> >>>>>>>> class
> >>>>>>>> lwgeom_pg.h:71: error: syntax error before 'LWGEOM_dropBBOX'
> >>>>>>>> lwgeom_pg.h:71: warning: type defaults to 'int' in declaration of
> >>>>>>>> 'LWGEOM_dropBBOX'
> >>>>>>>> lwgeom_pg.h:71: warning: parameter names (without types) in
> >>>>>>>> lwgeom_pg.h:71: warning: data definition has no type or storage
> >>>>>>>> class
> >>>>>>>> liblwgeom.c: In function 'trim_trailing_zeros':
> >>>>>>>> liblwgeom.c:158: warning: implicit declaration of function 'strchr'
> >>>>>>>> liblwgeom.c:158: warning: incompatible implicit declaration of
> >>>>>>>> built-in function 'strchr'
> >>>>>>>> liblwgeom.c:163: warning: implicit declaration of function 'strlen'
> >>>>>>>> liblwgeom.c:163: warning: incompatible implicit declaration of
> >>>>>>>> built-in function 'strlen'
> >>>>>>>> make[1]: *** [liblwgeom.o] Error 1
> >>>>>>>> On 1/12/06, strk at refractions.net <strk at refractions.net> wrote:
> >>>>>>>>> Please show some more lines - starting right before the *first*
> >>>>>>>>> warning during make - after a make clean.
> >>>>>>>>> --strk;
> >>>>>>>>> On Thu, Jan 12, 2006 at 08:39:25AM -0700, Assad Jarrahian wrote:
> >>>>>>>>>> I am talking about the latest release 1.10
> >>>>>>>>>> Yes it seems that I can find postgres.h
> >>>>>>>>>> pg_config --includedir-server
> >>>>>>>>>> What should I do with it?
> >>>>>>>>>> thanks.
> >>>>>>>>>> -assad
> >>>>>>>>>>> You're talking about postgis version ?
> >>>>>>>>>>> Can you find postgres.h under `/usr/bin/pg_config
> >>>>>>>>>>> --includedir-server` ?
> >>>>>>>>>>> --strk;
> >>>>>>>>>>> On Thu, Jan 12, 2006 at 01:46:17AM -0700, Assad Jarrahian wrote:
> >>>>>>>>>>>> David and all,
> >>>>>>>>>>>> Thanks. I got everything installed, but when installing
> >>>>>>>>>>>> postgis I
> >>>>>>>>>>>> got errors (see below).
> >>>>>>>>>>>> The configure summary:
> >>>>>>>>>>>> SUMMARY
> >>>>>>>>>>>> HOST_OS: linux-gnu
> >>>>>>>>>>>> PGSQL: /usr/bin/pg_config
> >>>>>>>>>>>>  GEOS: /usr/local/bin/geos-config (with C-API)
> >>>>>>>>>>>>  PROJ: dir=/usr/local
> >>>>>>>>>>>> ICONV: 1
> >>>>>>>>>>>> PORTNAME: linux
> >>>>>>>>>>>> PREFIX: /usr
> >>>>>>>>>>>> EPREFIX: ${prefix}
> >>>>>>>>>>>>    DOC: /usr/share/doc/postgresql-doc-8.1
> >>>>>>>>>>>>   DATA: /usr/share/postgresql/8.1/postgresql/contrib
> >>>>>>>>>>>>    MAN: /usr/share/postgresql/8.1/man
> >>>>>>>>>>>>    BIN: /usr/lib/postgresql/8.1/bin
> >>>>>>>>>>>>    EXT: /usr/lib/postgresql/8.1/lib (\$$libdir)
> >>>>>>>>>>>> and the errors:
> >>>>>>>>>>>> declaration of
> >>>>>>>>>>>> 'getGeometryOID'
> >>>>>>>>>>>> storage class
> >>>>>>>>>>>> declaration of
> >>>>>>>>>>>> 'box2df_to_box'
> >>>>>>>>>>>> storage class
> >>>>>>>>>>>> declaration of 'BOX2D_same'
> >>>>>>>>>>>> storage class
> >>>>>>>>>>>> declaration of
> >>>>>>>>>>>> 'BOX2D_overlap'
> >>>>>>>>>>>> storage class
> >>>>>>>>>>>> declaration of
> >>>>>>>>>>>> 'BOX2D_overleft'
> >>>>>>>>>>>> storage class
> >>>>>>>>>>>> declaration of 'BOX2D_left'
> >>>>>>>>>>>> storage class
> >>>>>>>>>>>> lwgeom_pg.h:44: error: syntax error before 'BOX2D_right'
> >>>>>>>>>>>> declaration of 'BOX2D_right'
> >>>>>>>>>>>> storage class
> >>>>>>>>>>>> declaration of
> >>>>>>>>>>>> 'BOX2D_overright'
> >>>>>>>>>>>> storage class
> >>>>>>>>>>>> declaration of
> >>>>>>>>>>>> 'BOX2D_overbelow'
> >>>>>>>>>>>> storage class
> >>>>>>>>>>>> declaration of 'BOX2D_below'
> >>>>>>>>>>>> storage class
> >>>>>>>>>>>> declaration of 'BOX2D_above'
> >>>>>>>>>>>> storage class
> >>>>>>>>>>>> declaration of
> >>>>>>>>>>>> 'BOX2D_overabove'
> >>>>>>>>>>>> storage class
> >>>>>>>>>>>> declaration of
> >>>>>>>>>>>> 'BOX2D_contained'
> >>>>>>>>>>>> storage class
> >>>>>>>>>>>> declaration of
> >>>>>>>>>>>> 'BOX2D_contain'
> >>>>>>>>>>>> storage class
> >>>>>>>>>>>> declaration of
> >>>>>>>>>>>> 'LWGEOM_getBBOX'
> >>>>>>>>>>>> storage class
> >>>>>>>>>>>> declaration of
> >>>>>>>>>>>> 'LWGEOM_addBBOX'
> >>>>>>>>>>>> storage class
> >>>>>>>>>>>> declaration of
> >>>>>>>>>>>> 'LWGEOM_dropBBOX'
> >>>>>>>>>>>> storage class
> >>>>>>>>>>>> 'strchr'
> >>>>>>>>>>>> 'strlen'
> >>>>>>>>>>>> make: *** [liblwgeom] Error 2
> >>>>>>>>>>>> On 1/12/06, Stefano Costa <steko at iosa.it> wrote:
> >>>>>>>>>>>>> Il giorno gio, 12/01/2006 alle 00.28 -0700, Assad Jarrahian
> >>>>>>>>>>>>> ha scritto:
> >>>>>>>>>>>>>> hey david and all,
> >>>>>>>>>>>>>> thanks for replying.
> >>>>>>>>>>>>>> I tried the first step and it raised an exception
> >>>>>>>>>>>>>> sudo apt-get postgresql-dev
> >>>>>>>>>>>>>> E: Invalid operation postgresql-dev
> >>>>>>>>>>>>> You should add an "install" just like this:
> >>>>>>>>>>>>> sudo apt-get install postgresql-dev
> >>>>>>>>>>>>> Regards,
> >>>>>>>>>>>>> Stefano
> >>>>>>>>>>>>> Stefano Costa
> >>>>>>>>>>>>> http://www.iosa.it Software Open Source per l'Archeologia
> >>>>>>>>>>>>> Jabber: steko at jabber.linux.it
> >>>>>>>>>>>>> GnuPG Key ID 1024D/0xD0D30245
> >>>>>>>>>>>>> Linux Registered User #385969 counter.li.org
> >>>>>>>>>>>>> _______________________________________________
> >>>>>>>>>>>>> postgis-users mailing list
> >>>>>>>>>>>>> postgis-users at postgis.refractions.net
> >>>>>>>>>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> >>>>>>>>>>> /"\    ASCII Ribbon Campaign
> >>>>>>>>>>> \ /    Respect for low technology.
> >>>>>>>>>>> X     Keep e-mail messages readable by any computer system.
> >>>>>>>>>>> / \    Keep it ASCII.
> >>>>>>>>> / \    Keep it ASCII.
> >>>>>> / \    Keep it ASCII.
