[postgis-users] Problem on ./configure
strk at refractions.net strk at refractions.net
Tue Jan 17 00:32:06 PST 2006
./configure looks for pg_config.
Is pg_config in your PATH ?
If it is not you can provide full path to it using
the --with-pgsql=<path> switch .
--strk;
On Mon, Jan 16, 2006 at 04:12:12PM -0300, Ezequias Rodrigues da Rocha wrote:
> >>Command: ./configure
> >>Error: configure: error: PostgreSQL is required by PostGIS
