[postgis-users] Problem on ./configure
Ezequias Rodrigues da Rocha ezequias at recife.pe.gov.br
Tue Jan 17 11:06:02 PST 2006
Actually not perfect. A problem occours on the generation of PostGIS.
See resoults:
make[1]: ** [liblwgeom.o] Erro 1
make[1]: Leaving directory
`/home/ezequias/1A/SuperProject/server/mapserver/postgis-1.1.0/lwgeom'
make: ** [liblwgeom] Erro 2
What up ?
Ezequias
Ezequias Rodrigues da Rocha escreveu:
> Perfect. Thank you so much
> Ezequias
> Randy James escreveu:
>> Try
>> /configure --with-pgsql=/usr/local/pgsql/bin --with-proj=/opt/proj-4.4.9
>> --- Ezequias Rodrigues da Rocha <ezequias at recife.pe.gov.br> wrote:
>>> Dear Jeff,
>>> It is been a rally for me but I need to finish this installation as
>>> soon as possible.
>>> So let's go.
>>> I installed the proj. I think it is installed properly now.
>>> The file projects.h is in
>>> /opt/proj-4.4.9/include
>>> I try to configure PostGIS but it remains with the same error
>>> message:
>>> [root at dc postgis-1.1.0]# ./configure
>>> --with-pgsql=/usr/local/pgsql/bin --with-proj=/opt/proj-4.4.9/include
>>> The error message is:
>>> checking for strings.h... yes
>>> checking for inttypes.h... yes
>>> checking for stdint.h... yes
>>> checking for unistd.h... yes
>>> checking iconv.h usability... yes
>>> checking iconv.h presence... yes
>>> checking for iconv.h... yes
>>> checking build system type... i686-pc-linux-gnu
>>> checking host system type... i686-pc-linux-gnu
>>> ./configure: line 3568: /usr/local/pgsql/bin: is a directory
>>> ./configure: line 3569: /usr/local/pgsql/bin: is a directory
>>> ./configure: line 3570: /usr/local/pgsql/bin: is a directory
>>> ./configure: line 3571: /usr/local/pgsql/bin: is a directory
>>> ./configure: line 3572: /usr/local/pgsql/bin: is a directory
>>> checking for geos-config... /usr/bin/geos-config
>>> checking for proj... /usr/bin/proj
>>> configure: error: Can't find proj dir.
>>> What I did incorrectly ?
>>> Ezequias
>>> Jeff Lounsbury escreveu:
>>>> I've never had any problems just installing from source
>>>> (ftp://ftp.remotesensing.org/proj/proj-4.4.9.tar.gz), very
>>> simple:
>>>> tar –xvzf proj-4.4.9.tar.gz
>>>> cd proj-4.4.9
>>>> /configure –prefix /opt/proj-4.4.9
>>>> make
>>>> su
>>>> make install
>>>> echo /opt/proj-4.4.9/lib >> /etc/ld.so.conf
>>>> ldconfig
>>>> If you don't have a practical problem using source that is...
>>> Sorry if
>>>> this is too obvious and you've already considered this option, I
>>>> thought there was a slight chance it might help... :-)
>>>> Cheers,
>>>> -Jeff
>>>> Frank Koormann wrote:
>>>>> * Ezequias Rodrigues da Rocha <ezequias at recife.pe.gov.br>
>>> [060117
>>>>> 15:42]:
>>>>>> I have no project-devel package here.
>>>>>> I just download the full packages for mapserver on this
>>> website:
>>>>>> http://mappinghacks.com/rpm/fedora/4/
>>>>>> Have anybody have a suggestion ?
>>>>> Hm, there isn't any proj-* file in the directory you pointed.
>>> However, I
>>>>> can find proj-4.4.9 runtime and devel-packages under
>>>>> http://mappinghacks.com/rpm/fedora/2/
>>>>> as well as
>>>>> http://mappinghacks.com/rpm/fedora/3/
>>>>> Regards,
>>>>>         Frank
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> postgis-users at postgis.refractions.net
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>>> http://ezequiasrocha.blogspot.com
>>> msn:ezequias at hotmail.com
>>> "the worst of democracies is still better than the best of
>>> dictatorship"
>> __________________________________________________
>> Do You Yahoo!?
>> Tired of spam?  Yahoo! Mail has the best spam protection around
>> http://mail.yahoo.com _______________________________________________
"the worst of democracies is still better than the best of dictatorship"
