[postgis-users] inside of a geometry
Stephen Woodbridge woodbri at swoodbridge.com
Thu Jan 19 11:46:45 PST 2006
Brent Pedersen wrote:
> hi, this may be a mapserver problem, but i'm trying to display the
> OUTLINE's of a polygon layer color coded according to an attributes.
> the problem is that the adjacent polygons essentially share a border so
> only one of those polygon's border's is visible:
> http://giifweb.cnr.berkeley.edu/fire/geoFRAP/060_247802000000.png
>  (ignore the circle)
> i tried using expand(the_geom, -0.1), but that doesn't work. is there a
> postgis to get the inner boundary of a polygon? (or a mapserver method
> to accomplish same?
expand only works on the bbox of the geometry. You might try buffer with
a negative number, but I suspect that will not work either.
-Steve W.
