[postgis-users] Upgrading from PostgreSQL 8.0 with PostGIS 0. 9 to PostgreSQL 8.1 with PostGIS 1.0
Mario Servin mservin at gmail.com
Fri Jan 20 08:00:45 PST 2006
Thanks Jeremy. I used that and now postgis_restore works to the end.
Unfortunately the geom column of my data again appear as a strange string of
characters where I expected to see something as POINT, LINE etc. I do not
know what else can I do .....
On 1/20/06, Sears, Jeremy <Jeremy.Sears at ccrs.nrcan.gc.ca> wrote:
> >>The postgis_restore.pl could create the dump list and also the dump
> ascii but then gives an error because it does not allow me to write down the
> password at the next >>step.
> I was having a simmilar problem. Each time I'd run postgis_restore.pl It
> would promt for my password 3 time before bailing, indicating that the
> password was incorrect. It was pointed out to me that this can be avoided by
> setting the following environment variables, PGUSER and PGPASSWORD. I also
> found it useful to specify PGHOST, PGPORT, and PGDATA as well. You can set
> the env variable at the cmmd prompt like this:
> >set PGUSER=username
> or you can set the in controlpanel-->system-->advanced-->
> hope that helps
> Jeremy
> -----Original Message-----
> *From:* postgis-users-bounces at postgis.refractions.net [mailto:
> postgis-users-bounces at postgis.refractions.net]*On Behalf Of *Mario Servin
> *Sent:* January 20, 2006 10:06 AM
> *To:* postgis-users at postgis.refractions.net
> *Subject:* [postgis-users] Upgrading from PostgreSQL 8.0 with PostGIS 0.9to PostgreSQL
> Hi everybody,
> I failed completely to restore my data from a PostgreSQL 8.0 with PostGIS
> 0.9 to PostgreSQL 8.1 with PostGIS 1.0. I have both versions of PosgreSQL
> running in Windows. I follow instructions in PostGIS docs from the
> PostgreSQL installation for upgrading. The postgis_restore.pl could create
> the dump list and also the dump ascii but then gives an error because it
> does not allow me to write down the password at the next step. As I know
> something about Perl I tried to modify the script without success.
> Additionally, I still have the results from the old shp2pgsql and so I
> tried to insert the data form psql using \i mysqlinsertionscript.sql.
> Tables are created ok, but geom columns results in meaningless characters
> where it is supossed to be something like "POINT (- 66.046532 -21.951437)"
> for example.
> Can anybody help me?.
> Regards,
>             Mario Servin
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060120/1e4b6f75/attachment.html>
