[postgis-users] Upgrading from PostgreSQL 8.0 with PostGIS 0.9 to PostgreSQL 8.1 with PostGIS 1.0
Mario Servin mservin at gmail.com
Fri Jan 20 10:50:08 PST 2006
By the way Stephen, it seems that there's something missed at the new
the_geom column:
in older versions geometry data was stored as
SRID=-1;POINT(-66.046532 -21.951437)
Now the select asewkt shows the following:
What happens with SRID?
On 1/20/06, Mario Servin <mservin at gmail.com> wrote:
> Thanks Stephen! now I can see them!!. How can I change the default
> behavior for seeing as simple text ?
> On 1/20/06, Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
> > Mario Servin wrote:
> > > Hi everybody,
> > [snip]
> > > Additionally, I still have the results from the old shp2pgsql and so I
> > > tried to insert the data form psql using \i mysqlinsertionscript.sql.
> > > Tables are created ok, but geom columns results in meaningless
> > > characters where it is supossed to be something like "POINT (-
> > 66.046532
> > > -21.951437)" for example.
> > The default behavior changed. Try:
> > select aswkt(the_geom) from table;
> > the default is to display the geometry in a hex representation of the
> > binary.
> > -Steve W.
> > > Can anybody help me?.
> > > Regards,
> > >             Mario Servin
> > > _______________________________________________
> > > postgis-users mailing list
> > > postgis-users at postgis.refractions.net
> > > http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060120/6dd1eb5f/attachment.html>
