[postgis-users] re: shp2sql and UTF8 question on Windows
Markus Schaber schabi at logix-tt.com
Wed Jan 25 01:01:53 PST 2006
Hi, Randy,
Randy George wrote:
> I have a database created with ENCODING = 'UTF8'
> psql:test.sql:15: ERROR:  invalid UTF-8 byte sequence detected near byte
> 0xa1
> CONTEXT:  COPY county, line 1, column NAME: "Manatí"
We had a similar problem and solved it without the -W switch:
(echo 'set client_encoding TO LATIN9;' ; shp2psql blah blubb) | psql foo bar
Thus we shifted the encoding to the backend. This works with all
encodings that are ASCII-compatible and so retain the SQL commands.
(thus all ISO Latin encondings as well as UTF-8, but not UTF-16 or EBCDIC).
I don't know whether the pipe magic works under windows without cygwin,
but you may use the following trick: First, dump the SQL into a
temporary file:
shp2psql blah blubb > path\to\tempfile.sql
and then run psql to set the encoding and insert the dump:
geodb=# set client_encoding TO LATIN9;
geodb=# \i path\to\tempfile.sql
Maybe we should add an "send client_encoding" command switch (that is
mutually exclusive with -W) to shp2pgsql. I'll have a look into this.
Markus Schaber | Logical Tracking&Tracing International AG
Dipl. Inf.     | Software Development GIS
Fight against software patents in EU! www.ffii.org www.nosoftwarepatents.org
