[postgis-users] re: shp2sql and UTF8 question on Windows
Mark Cave-Ayland m.cave-ayland at webbased.co.uk
Fri Jan 27 02:45:04 PST 2006
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-
> bounces at postgis.refractions.net] On Behalf Of Markus Schaber
> Sent: 26 January 2006 18:37
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] re: shp2sql and UTF8 question on Windows
(cut)
> AFAIK, SJIS has a different symbol on the ascii position of \ so the
> backslashes output by shp2pgsql will not be recognized by postgresql,
> leading to strange effects.
> Markus
Ahhh now I understand a bit better - my conversion was just from LATIN-1 to
UNICODE. So perhaps we do need to keep the iconv code in there for cases
like this...
Kind regards,
Mark.
WebBased Ltd
17 Research Way
Plymouth
PL6 8BT
T: +44 (0)1752 797131
F: +44 (0)1752 791023
http://www.webbased.co.uk
http://www.infomapper.com
http://www.swtc.co.uk
This email and any attachments are confidential to the intended recipient
and may also be privileged. If you are not the intended recipient please
delete it from your system and notify the sender. You should not copy it or
use it for any purpose nor disclose or distribute its contents to any other
person.
