[postgis-users] MultiLineString to Point Geometry
Barend Köbben kobben at itc.nl
Mon Jan 30 06:36:24 PST 2006
Try something like this:
-- STEP 1: get maximum of NumGeometries into tmp table
CREATE TABLE tmp (maxnumgeoms int4);
INSERT into tmp
 (select [someIDvalue] from [yourLinestringTable] where [someIDvalue] <=
  (select max(NumGeometries(the_geom)) from [yourLinestringTable] )
-- STEP 2: create [yourPointsTable]
CREATE SEQUENCE  [yourPointsTable]_id_seq
  INCREMENT 1
  MINVALUE 1
  MAXVALUE 9223372036854775807
  START 1
  CACHE 1;
CREATE TABLE  [yourPointsTable]
  id int4 NOT NULL DEFAULT nextval('[yourPointsTable]_id_seq'::regclass),
  the_geom geometry,
  CONSTRAINT [yourPointsTable]_pkey PRIMARY KEY (id),
  CONSTRAINT enforce_dims_the_geom CHECK (ndims(the_geom) = 2),
  CONSTRAINT enforce_geotype_the_geom CHECK (geometrytype(the_geom) = 'POINT'::text OR the_geom IS NULL),
  CONSTRAINT enforce_srid_the_geom CHECK (srid(the_geom) = <yourSRID>)
WITH OIDS;
CREATE INDEX [yourPointsTable]_the_geom_gist
  ON [yourPointsTable] USING gist(the_geom);
-- STEP 3: insert exploded polylines
insert into [yourPointsTable] (the_geom)
 select [someIDvalue] , GeometryN([yourMultiStringTable].the_geom,maxnumgeoms)
 from tmp , [yourMultiStringTable]
____________________________
Barend Köbben
International Institute for Geo-information Sciences and  Earth Observation (ITC)
PO Box 6, 7500AA Enschede (The Netherlands)
ph: +31-(0)534874253; fax: +31-(0)534874335
_____________________________
Type: application/ms-tnef
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060130/48ee5248/attachment.bin>
