[postgis-users] JAVA and post GIS
Gilbert, Antoine AGilbert at korem.com
Mon Jan 30 13:39:09 PST 2006
All these examples not working with the current versions
  _____
From: Fatemeh Abbasinejad [mailto:fabbasinejad at yahoo.com]
Sent: January 30, 2006 4:09 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] JAVA and post GIS
Hi.
I sae the code and tried to execute it on my own tables.Ther were some
problems:
First when trying to add data types it would give me a warning that the
method addDataType has been deprecated.
Also when I tried to cast to PGeometry  it would throw
"ClassCastException".Here is my code:
((PGConnection)conn).addDataType("geometry","org.postgis.PGgeometry");
Statement s = conn.createStatement();
ResultSet r = s.executeQuery("select center(geometry)as mycenter from
land");
while( r.next() )
        PGgeometry mycenter = (PGgeometry)r.getObject(1);
        System.out.println(mycenter.toString());
I have a table called "land" which has an attribute "geometry" of type
Circle.I want to retreive the center of the circle which is of type
"Point".
Have I casted wrong? I also tried casting to "Point" but it would give
the same exception. What should I do?
Emily Gouge <egouge at refractions.net> wrote:
	There is some documentation and an example on connecting to
PostGIS using Java. See:
	http://postgis.refractions.net/docs/ch04.html#id2789526
	You can add a datatype to the postgres connection and then the
getObject() call will return a
	PGGeometry object:
((org.postgresql.Connection)conn).addDataType("geometry","org.postgis.PG
geometry");
	Additionally you can also check out the postgis_jts jar, which
provides the ability to return a
	JtsGeometry object (and subsequently to convert this object to a
JTS Geometry object).
	Emily
	Fatemeh Abbasinejad wrote:
	> I am new to PostGIS. Does anyone know how we can retrieve our
defined data types
	> (like point,circle,...) from a ResultSet in java. I used
getObject but it didn't work.
	> -fatemeh
	> Bring words and photos together (easily) with
	> PhotoMail - it's free and works with Yahoo! Mail.
	> postgis-users mailing list
  _____
What are the most popular cars? Find out at Yahoo! Autos
<http://us.rd.yahoo.com/evt=38382/_ylc=X3oDMTEzNWFva2Y2BF9TAzk3MTA3MDc2B
HNlYwNtYWlsdGFncwRzbGsDMmF1dG9z/*http:/autos.yahoo.com/newcars/popular/t
hisweek.html%20%0d%0a>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060130/a65f0ed0/attachment.html>
