AW: [postgis-users] Comparison of geometries
Düster Horst Horst.Duester at bd.so.ch
Tue Jan 31 05:32:29 PST 2006
Hallo Darren
Thank you for your response.
Of course you cannot see any difference due to I sent the wrong layer to the
list. Now I attach the two correct shapes with the differences which do not
work. Please excuse the confusion.
Import the attached shapes new_layer.shp and old_layer.shp to your PostGIS
DB. When you query with
 select the_geom, art from old_layer
 except
 select the_geom, art from new_layer
the query supplies 1 Record and that's wrong!
with
 select the_geom::text, art from old_layer
 except
 select the_geom::text, art from new_layer
the query supplies 2 Records and that's correct!
I can't see any reason for this difference.
With best regards
Dr. Horst Düster
GIS-Koordinator, Stv. Amtsvorsteher
Kanton Solothurn
Amt für Geoinformation
Abteilung SO!GIS Koordination
Rötistrasse 4
CH-4501 Solothurn
Tel.: ++41 (0)32 627 25 32
Fax: ++41 (0)32 627 22 14
horst.duester at bd.so.ch
www.sogis.so.ch
> -----Ursprüngliche Nachricht-----
> Von: Darren Houston [mailto:dhouston at beyondcompliance.ca]
> Gesendet am: Dienstag, 31. Januar 2006 08:57
> An: PostGIS Users Discussion
> Betreff: Re: [postgis-users] Comparison of geometries
> Hello Horst,
> Except works as expected for me. PostgreSQL will compare my
> lwgeom geometries
> and provide the correct returned results. You can try except all for
> duplicate rows, but if no results are being returned that
> probably won't help
> you. You could also cast your geometries to text (or another
> data type) and
> try comparing those values. Also, for a check, if you perform
> asewkt(difference()) on the geometries from one table to
> geometries in the
> other, do you receive an empty geometry collection (i.e. the
> geometries are
> equall)? Maybe your geometries are really equal.
> Just some brain garbage from me that might give you some ideas,
> Darren H.
> On Tuesday 31 January 2006 00:34, Düster Horst wrote:
> > I try to compare two geometry tables with the intension to
> detect the
> > geometrical and attributive differences between these two
> tables. For
> > example I attach two tables new and old. Now I want to detect all
> > geometries of the table old which are not in table new. For
> this issue I
> > use the following query
> > select the_geom, art from "old"
> > except
> > select the_geom, art from "new"
> > but the query doesn't supply the correct result. The
> correct result should
> > contain two records but the query results 0 records. Now
> I'm doubt about
> > whether  it's allowed to use geometries in an except clause
> like other
> > datatypes?? Otherwise in other tables 100% of different
> geometries will be
> > detected by the query above!
> > My System:
> > RedHat AS4
> > PostgreSQL 8.1.1
> > POSTGIS="1.0.6" GEOS="2.1.1" PROJ="Rel. 4.4.8, 3 May 2004" USE_STATS
> > DBPROC="0.3.0" RELPROC="0.3.0"
> > I'll appreciate every hint.
> > Best regards
> > Dr. Horst Düster
> > Kanton Solothurn
> > Rötistrasse 4
> > CH-4501 Solothurn
> > www.sogis.so.ch
> postgis-users mailing list
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060131/7a268d48/attachment.obj>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060131/7a268d48/attachment-0001.obj>
