[postgis-users] need help; A shp2pgsql bug?
strk at refractions.net strk at refractions.net
Thu Jul 6 14:59:36 PDT 2006
Did you use shp2pgsql from postgis 1.1.3 ?
How did you invoke shp2pgsql ?
What RCSID does shp2pgsql with no args report ?
--strk;
On Thu, Jul 06, 2006 at 10:32:54AM -0400, Fay Du wrote:
> Hi list:
> I have a street center line shape file (I cut the error area into a
> small file and put in attachment). For one street, there are two
> segments (it should be one), one on the top of another. When I use
> shp2pgsql, one is loaded into to the table in PostGIS correctly, another
> one does not. The second road segment is loaded into PostGIS table as 2
> rows, and none of them is right. Why? Is it a shp2pgsql bug? How can I
> avoid it?
> After I load the file, I checked the 2 rows
> select astext(the_geom) from st_centerline
> where gid = 6605 or gid = 25113 or gid = 29190;
>  (they are same, one on another's top, and orginal file has 2 segment.)
> "MULTILINESTRING((335670.595996869 5040033.68488063,335723.599695015
> 5040081.67951423))"
> "MULTILINESTRING((335670.595996869 5040033.68488063,167861.8 0))"
> "MULTILINESTRING((167861.8 0,335723.599695015 5040081.67951423))"
> I noticed that the last 2 geometry is separate at point (167861.8 0).
> They should be one geometry feature. How it happened? I have 6 errors
> like this when I run shp2pgsql. Total feature (road segment) in the
> original shape file is 28541.
>  It does not look like original data problem.  I use Universal
> Translator in MapInfo to import the same shape file into MapInfo tab
> file, both road segments were successfully import into tab file. The
> above 2 road segments are still overlap in tab file.
> Any help will be appreciated.
> Fay
> postgis-users mailing list
 /"\    ASCII Ribbon Campaign
 \ /    Respect for low technology.
  X     Keep e-mail messages readable by any computer system.
 / \    Keep it ASCII.
