[postgis-users] time consuming intersection query
Arnaud Lesauvage thewild at freesurf.fr
Fri Jun 2 06:17:08 PDT 2006
Nelson Guda a écrit :
> Hi all,
> I'm trying to do an intersection query to find which elements of one
> database (county shapes) intersects with another database of
> thousands of shapes.  The query seems to get stuck running, and I'm
> not sure why.  Here is the language I used:
> create table iracounties as select c.name, c.state_name, c.id from
> counties as c, iraname as i where intersects(c.the_geom,i.wkb_geometry)
> Am I doing something wrong, or is there some way to make this more
> efficient?
Hi Nelson
Intersects() is a very time consumming funtion, which does not use
indexes, because only bounding-box-based operators use indexes.
You should change your query to something like :
from  counties as c, iraname as i
where c.the_geom && i.wkb_geometry and
intersects(c.the_geom,i.wkb_geometry);
If your geometry columns are indexed, postgresql will use the
index to evaluate "c.the_geom && i.wkb_geometry", which means
"bounding bos of c.the_geom overlaps bounding box of i.wkb_geometry".
You should read
http://postgis.refractions.net/docs/ch04.html#id2919118
about using indexes with geometries.
Arnaud
