[postgis-users] Problems with Debian and Postgis
TECHER David davidtecher at yahoo.fr
Fri Jun 9 01:38:04 PDT 2006
English:
Hi
It is possible for U to completly uninstall postgresql 7.4 from apt-get
or others form deb
If it is the case...The last solution => to install everything from source!
I don't love this solution but maybe....
Here possible documentation for Debian (but testing) in French ;-)
PDF: http://www.postgis.fr/documentation/debian/postgis-1.1.2/pdf/doc.pdf
HTML:
http://www.postgis.fr/documentation/debian/postgis-1.1.2/html/index.html
That's all I can do for U!
Didrik Pinte a écrit :
>Le vendredi 09 juin 2006 à 09:24 +0200, Nabil Servais a écrit :
>>I use this repository:
>># cartoweb
>>deb http://dev.camptocamp.com/packages/debian/prod/ sarge main
>>deb-src http://dev.camptocamp.com/packages/debian/prod/ sarge main
>>#debian-gis
>>deb http://pkg-grass.alioth.debian.org/debian-gis unstable main contrib
>>deb-src http://pkg-grass.alioth.debian.org/debian-gis unstable main contrib
>Use only the cartoweb repositories. The debian-gis unstable repositories
>aren't compatible with the Sarge version at the moment.
>You will find everything you need on the camptocamp repositories
>(postgres8 and postgis).
>Didrik
>_______________________________________________
>postgis-users mailing list
>postgis-users at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060609/2c0841ba/attachment.html>
