[postgis-users] Installation postGIS1.1.2
strk at refractions.net strk at refractions.net
Mon Jun 12 03:08:05 PDT 2006
On Mon, Jun 12, 2006 at 12:05:00PM +0200, Stüwe Rolf wrote:
> Hello,
> I have a problem by installing postgis 1.1.2 with postgres 8.1.4 under Suse linux /9 64 bit Version.
> It seems that the configure and make Skript does not find the right path of the postgres-Version.
> For using the configure-Skript I have to set the PATH on the postgres ... pg_config-file.
You shoul not need that, --with-pgsql=path/to/pg_config should do.
If you still have problem please include the errors and warnings
you're getting in each phase of the build.
--strk;
