[Spam:medium] Re: [postgis-users] Installation postGIS1.1.2
strk at refractions.net strk at refractions.net
Mon Jun 12 06:55:18 PDT 2006
On Mon, Jun 12, 2006 at 03:17:49PM +0200, Stüwe Rolf wrote:
> I think it i sa problem with the paths:
> the configure of postgres is :
> LDFLAGS=-lstdc++  ./configure --prefix=/usr1/postgres/pgsql_814  --without-zlib
> and all paths are correct in the log-files
> (I want to install in /usr1/postgres/pgsql_814 instead of /usr/local)
> the configure if postGIS is:
> ./configure  --with-pgsql=/usr1/src/postgres/postgresql-8.1.4/src/bin/pg_config/pg_config
> but the summary says :
> PORTNAME: linux
>    PREFIX: /usr1/postgres/pgsql814
>   EPREFIX: ${prefix}
>       DOC: /usr1/postgres/pgsql814/doc/contrib
>      DATA: /usr1/postgres/pgsql814/share/contrib
>       MAN: /usr1/postgres/pgsql814/man
>       BIN: /usr1/src/postgres/postgresql-8.1.4/src/bin/pg_config
>       EXT: /usr1/postgres/pgsql814/lib (\$$libdir)
> the path from postGIS is not ...pgsql_814 but ...pgsql814. This is the path of a former compilation, but it is not actual,
Are you referring to the probin field from pg_proc ?
> I did the next compilation with ...pgsql_814  and did a "make clean" before and removed the old, wrong directory.
> Where can postGIS remembered the older, wrong path
Did you source lwpostgis_upgrade.sql ?
--strk;
