AW: [Spam:medium] Re: [postgis-users] Installation postGIS1.1.2
TECHER David davidtecher at yahoo.fr
Mon Jun 12 07:00:32 PDT 2006
To my mind, I will do this
PostgreSQL:
make clean distclean
LDFLAGS=-lstdc++  ./configure --prefix=/usr1/postgres/pgsql_814  --without-zlib
make
make install <------------ don't forget this!
PostGIS:
export PATH=/usr1/postgres/pgsql_814/bin:$PATH
Tell us if
which pg_config
give U
/usr/postgres/pgsql_814/bin/pg_config
Then
./configure --with-pgsql=/usr/postgres/pgsql_814/bin/pg_config
Stüwe Rolf a écrit :
>I think it i sa problem with the paths:
>the configure of postgres is :
>and all paths are correct in the log-files
>(I want to install in /usr1/postgres/pgsql_814 instead of /usr/local)
>the configure if postGIS is:
>./configure  --with-pgsql=/usr1/src/postgres/postgresql-8.1.4/src/bin/pg_config/pg_config
>but the summary says :
>PORTNAME: linux
>   PREFIX: /usr1/postgres/pgsql814
>  EPREFIX: ${prefix}
>      DOC: /usr1/postgres/pgsql814/doc/contrib
>     DATA: /usr1/postgres/pgsql814/share/contrib
>      MAN: /usr1/postgres/pgsql814/man
>      BIN: /usr1/src/postgres/postgresql-8.1.4/src/bin/pg_config
>      EXT: /usr1/postgres/pgsql814/lib (\$$libdir)
>the path from postGIS is not ...pgsql_814 but ...pgsql814. This is the path of a former compilation, but it is not actual,
>I did the next compilation with ...pgsql_814  and did a "make clean" before and removed the old, wrong directory.
>Where can postGIS remembered the older, wrong path
>with regards
>Rolf
>-----Ursprüngliche Nachricht-----
>Von: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] Im Auftrag von strk at refractions.net
>Gesendet: Montag, 12. Juni 2006 12:08
>An: postgis-users at postgis.refractions.net
>Betreff: [Spam:medium] Re: [postgis-users] Installation postGIS1.1.2
>On Mon, Jun 12, 2006 at 12:05:00PM +0200, Stüwe Rolf wrote:
>>Hello,
>>I have a problem by installing postgis 1.1.2 with postgres 8.1.4 under Suse linux /9 64 bit Version.
>>It seems that the configure and make Skript does not find the right path of the postgres-Version.
>>For using the configure-Skript I have to set the PATH on the postgres ... pg_config-file.
>You shoul not need that, --with-pgsql=path/to/pg_config should do.
>If you still have problem please include the errors and warnings you're getting in each phase of the build.
>--strk;
>_______________________________________________
>postgis-users mailing list
>http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060612/510a8324/attachment.html>
