AW: AW: [Spam:medium] Re: [postgis-users] Installation postGIS1.1.2
Stüwe Rolf Rolf.Stuewe at stadt.wuppertal.de
Tue Jun 13 00:58:11 PDT 2006
Hello,
i did the make clean distclean
and set the PATH   BUT:
which pg_config gives me:
/usr1/src/postgres/postgresql-8.1.4/src/bin/pg_config/pg_config
that is the path where the cources are
--strk  wrote:
Are you referring to the probin field from pg_proc ?
answere: NO
Did you source lwpostgis_upgrade.sql ?
answere: NO
Rolf
Von: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] Im Auftrag von TECHER David
Gesendet: Montag, 12. Juni 2006 16:01
An: PostGIS Users Discussion
Betreff: Re: AW: [Spam:medium] Re: [postgis-users] Installation postGIS1.1.2
To my mind, I will do this
PostgreSQL:
LDFLAGS=-lstdc++  ./configure --prefix=/usr1/postgres/pgsql_814  --without-zlib
make
make install <------------ don't forget this!
PostGIS:
export PATH=/usr1/postgres/pgsql_814/bin:$PATH
Tell us if
which pg_config
give U
/usr/postgres/pgsql_814/bin/pg_config
Then
./configure --with-pgsql=/usr/postgres/pgsql_814/bin/pg_config
Stüwe Rolf a écrit :
	I think it i sa problem with the paths:
	the configure of postgres is :
	and all paths are correct in the log-files
	(I want to install in /usr1/postgres/pgsql_814 instead of /usr/local)
	the configure if postGIS is:
	./configure  --with-pgsql=/usr1/src/postgres/postgresql-8.1.4/src/bin/pg_config/pg_config
	but the summary says :
	PORTNAME: linux
	   PREFIX: /usr1/postgres/pgsql814
	  EPREFIX: ${prefix}
	      DOC: /usr1/postgres/pgsql814/doc/contrib
	     DATA: /usr1/postgres/pgsql814/share/contrib
	      MAN: /usr1/postgres/pgsql814/man
	      BIN: /usr1/src/postgres/postgresql-8.1.4/src/bin/pg_config
	      EXT: /usr1/postgres/pgsql814/lib (\$$libdir)
	the path from postGIS is not ...pgsql_814 but ...pgsql814. This is the path of a former compilation, but it is not actual,
	I did the next compilation with ...pgsql_814  and did a "make clean" before and removed the old, wrong directory.
	Where can postGIS remembered the older, wrong path
	with regards
	Rolf
	-----Ursprüngliche Nachricht-----
	Von: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] Im Auftrag von strk at refractions.net
	Gesendet: Montag, 12. Juni 2006 12:08
	An: postgis-users at postgis.refractions.net
	Betreff: [Spam:medium] Re: [postgis-users] Installation postGIS1.1.2
	On Mon, Jun 12, 2006 at 12:05:00PM +0200, Stüwe Rolf wrote:
		Hello,
		I have a problem by installing postgis 1.1.2 with postgres 8.1.4 under Suse linux /9 64 bit Version.
		It seems that the configure and make Skript does not find the right path of the postgres-Version.
		For using the configure-Skript I have to set the PATH on the postgres ... pg_config-file.
	You shoul not need that, --with-pgsql=path/to/pg_config should do.
	If you still have problem please include the errors and warnings you're getting in each phase of the build.
	--strk;
	postgis-users mailing list
	http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060613/4251ca34/attachment.html>
