[postgis-users] length and area in the schema
Emilia Venturato venturato at faunalia.it
Fri Jun 16 05:53:20 PDT 2006
Hi all,
I use postgresql/postgis (PostgreSQL 8.1.4/ POSTGIS 1.1.2) on Debian etch. I
have database with schemas.
I found a problem with length and area functions when geometric tables are in
the schema.
It seems use different function for lenght where search_path is limited to the
schema.
I think this is misleading, as the user have problems knowing which length and
area (s)he's getting.
Someone could help me?
thanks
Lia
More information:
LENGTH:
--I have a geometric table (linestring) in the schema 'pi_cens':
 \d pi_cens.hydroschema_1
      Tabella "pi_cens.hydroschema_1"
 Colonna  |      Tipo       | Modificatori
 gid      | integer         |
 cat      | bigint          |
 the_geom | public.geometry |
-- if I do:
set search_path to public;
select gid, length (the_geom) as length, public.length(the_geom) as
public_length from pi_cens.hydroschema_1 order by gid;
--results are:
gid  |      length      |  public_length
    1 | 284.579119841808 | 284.579119841808
    2 | 278.483583486187 | 278.483583486187
    3 | 564.156704174909 | 564.156704174909
    4 | 190.820394680818 | 190.820394680818
    5 | 1224.30798443593 | 1224.30798443593
-- if I do instead (the same query but with different search_path):
set search_path to pi_cens;
    1 |    114 | 284.579119841808
    2 |    130 | 278.483583486187
    3 |    178 | 564.156704174909
    4 |     98 | 190.820394680818
    5 |    402 | 1224.30798443593
AREA:
--I have a geometric table (polygon) in the schema 'pi_cens':
\d pi_cens.fieldschema
          Tabella "pi_cens.fieldschema"
 gid      | integer               |
 cat      | integer               |
 label    | character varying(24) |
 the_geom | geometry
-- If I do:
select gid, area (the_geom) as area, public.area(the_geom) as public_area from
pi_cens.fieldschema order by gid;
--results are:
 gid |       area       |   public_area
   0 | 3051647.04492188 | 3051647.04492188
   1 | 338179.840087891 | 338179.840087891
   2 |  89976863.703125 |  89976863.703125
   3 |  89976863.703125 |  89976863.703125
   4 |  705469.06640625 |  705469.06640625
   5 | 661486.389648438 | 661486.389648438
--results are:
   0 |        3524218 | 3051647.04492188
   1 |     386083.875 | 338179.840087891
   2 | 187038117.5625 |  89976863.703125
   3 | 187038117.5625 |  89976863.703125
   4 |     742453.125 |  705469.06640625
   5 |       688366.5 | 661486.389648438
Emilia Venturato
email+jabber: venturato at faunalia.it
www.faunalia.it
Tel: (+39) 347-2770007 Tel+Fax: (+39) 0587-213742
Piazza Garibaldi 5 - 56025 Pontedera (PI), Italy
