[postgis-users] shp2pgsql bug?
strk at refractions.net strk at refractions.net
Fri Jun 16 07:14:51 PDT 2006
Never mind, I could reproduce the problem with current head
and have fixed it. Can give CVS a try  ?
I added support for loader/dumper test, automatically run
by 'make test'. Currently tests for MULTILINE in all dimensions
are provided.
--strk;
On Fri, Jun 16, 2006 at 11:51:03AM +0200, strk at refractions.net wrote:
> Which versions are you using of both  pgsql2shp and shp2pgsql ?
> --strk;
> On Fri, Jun 16, 2006 at 03:23:18PM +0930, Eric Lam wrote:
> > Hello list,
> > I am back porting geometries I have loaded in postgresql8.x with postgis
> > 1.x to a postgresql 7.4.x with postgis 0.8.x
> > I am doing a:
> > pgsql2shp -f tmp.shp -g the_geom data MLSTable
> > shp2pgsql -s 4283 -c -g the_geom -w tmp.shp MLSTable > table.sql
> > All geometries are multilinestrings. However up until recently, I have
> > only ever had 1 linestring in the multilinestring.
> > For geometries with more than 1 linestring in the multilinestring there
> > is a comma at the start of every extra linestring except the first.
> > eg MULTILINESTRING( (12 34, 23 34, 14 51),(,25 43,34 23,34 54),(,76
> > 45,34 23))
> > Is this a known problem? Is there something I am missing?
> > At the moment I have piped the file through sed to remove the extra
> > comma before loading into the older database.
> > This is loading fine, however ....
> postgis-users mailing list
 /"\    ASCII Ribbon Campaign
 \ /    Respect for low technology.
  X     Keep e-mail messages readable by any computer system.
 / \    Keep it ASCII.
