[postgis-users] Error using pgsql2shp
Bruce Rindahl rindahl at lrcwe.com
Fri Jun 16 07:51:19 PDT 2006
v1.83 works fine, 1.84 and 1.85 gives the error.  Do you have a diff from
1.83 so I can test if it is the compiler?
Thanks
Bruce
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
strk at refractions.net
Sent: Friday, June 16, 2006 3:49 AM
To: 'PostGIS Users Discussion'
Subject: Re: [postgis-users] Error using pgsql2shp
pgsql2shp sets database name using PGDATABASE environment
variable. If win has its own way of specifying
this info in the environment do it manually before invoking pgsql2shp.
See sources for more informations.
--strk;
On Wed, Jun 14, 2006 at 03:17:05PM -0600, Bruce Rindahl wrote:
> Ah if it were only possible.  Clients pay the bills.
> Sent: Wednesday, June 14, 2006 3:16 PM
> To: postgis-users at postgis.refractions.net
> On Wed, Jun 14, 2006 at 03:08:49PM -0600, Bruce Rindahl wrote:
> > I am trying to convert a PostgreSQL/PostGIS table to a shapefile.  The
> table
> > looks fine and the geometry is good based on a web application.  PostGIS
> > version 1.1.2 and the RCSID for pgsql2shp is:
> > $Id: pgsql2shp.c,v 1.84 2006/04/18 14:09:28 strk Exp $
> > My command line is:
> > pgsql2shp -f test.shp DWR dwr_gis
> > where the database is DWR and the table is dwr_gis
> > I get:
> > FATAL:  database "Bruce" does not exist
> > "Bruce" is my user name on WinXP
> > The help options show the command should work - any ideas?
> Stop using proprietary software ?
> --strk;
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
