[postgis-users] Re: new entry for spatial_ref_sys.sql - Austrian "standard" projection
Gabriel Ebner ge at gabrielebner.at
Sun Jun 18 02:07:00 PDT 2006
On Sun, Jun 18, 2006 at 01:38:56AM +0200, Michael Haberler wrote:
> In Austria most geodata companies, and the land survey use something called
> the "Bundesmeldenetz" projection which is close to EPSG 31287 but not quite.
Note that this isn't the Bundesmeldenetz, which is a transverse mercator
projection with central meridians 28, 31, and 34 degrees east of Ferro in the
MGI datum.
Small guide to Austrian EPSG codes:
  31284 - BMN M28
  31285 - BMN M31
  31286 - BMN M34
  31287 - Lambert (which is what you're probably looking for)
> [...] but not quite.
Apparently PostGIS does not get datum transformation right for these SRS.
You'd just have to add
+towgs84=577.326,90.129,463.919,5.137,1.474,5.297,2.4232
  Gabriel.
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060618/dac7f1f9/attachment.pgp>
