[postgis-users] Re: Re: new entry for spatial_ref_sys.sql - Austrian "standard" projection
Michael Haberler mah at inode.at
Sun Jun 18 04:48:37 PDT 2006
ok, I'll dig out some reference and usage information for this projection
yes, I noticed the 60km offset when my points showed up in the wrong
city ;-)
-Michael
Gabriel Ebner schrieb:
> On Sun, Jun 18, 2006 at 12:49:23PM +0200, Michael Haberler wrote:
>> I got this projection example from a  local GIS company, and it seems to work for data from different sources so far
> Then it might be ok for your dataset, however it doesn't look like anything
> standard.  Do you notice a 150m shift between the dataset and other data (cf.
> datum transformation)?
>> the only difference I can discern from EPSG 31287 is +lat_0=48 instead of  +lat_0=47.5
> And the possible datum shift.
>> I'm not a projection expert.. is your parameter set equivalent to this change in results?
> There's just a difference of 60km between the y-coordinates. :)
> So the projection you've been given seems to be the right one for the dataset,
> even though it's not any one I know of.
>   Gabriel.
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060618/ea315985/attachment.html>
No virus found in this outgoing message.
Checked by AVG Free Edition.
Version: 7.1.394 / Virus Database: 268.9.0/368 - Release Date: 16.06.2006
