[postgis-users] 1.1.3 Release
Paul Ramsey pramsey at refractions.net
Fri Jun 30 22:01:33 PDT 2006
As heard on postgis-devel, 1.1.3 is now available.  Downloads from
<http://postgis.refractions.net/download/>
The 1.1.3 release includes numerous bug fixes and some new
functionality. This release includes standard support for long
transactions, which should be useful for a number of client
applications.
NEW Long Transactions support.
Can run the regress tests with 'make check' now.
New regress test support for loader/dumper.
BUGFIX in pgsql2shp successful return code.
BUGFIX in shp2pgsql handling of MultiLine WKT.
BUGFIX in affine() failing to update bounding box.
WKT parser: forbidden construction of multigeometries with EMPTY
elements (still supported for GEOMETRYCOLLECTION).
Added --with-proj-libdir and --with-geos-libdir configure switches.
JDBC:
Improved regression tests: MultiPoint and scientific ordinates
Fixed some minor bugs in jdbc code
Added proper accessor functions for all fields in preparation of
making those fields private later
Support for build Tru64 build.
Use Jade for generating documentation.
NEW DumpRings() function.
BUGFIX in distance(poly,poly) giving wrong results.
NEW AsHEXEWKB(geom, XDR|NDR) function.
Don't link pgsql2shp to more libs then required.
Initial support for PostgreSQL 8.2.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060630/2627651b/attachment.html>
