[postgis-users] installing postgis in Ubuntu 5.10(Breezy)
Mikael Schröder miscx at spray.se
Tue Mar 7 11:10:17 PST 2006
I have only libgeos2c2 not libgeos2c2a
so where do I find libgeos2c2a?
/Regards Mikael
tis 2006-03-07 klockan 20:06 +0100 skrev Mikael Schröder:
> That was a quick response!
> I get the following message when I try to install
> postgresql-8.1-postgis1: Could not select all packages for the
> installation or upgrade. The following packages have unresolved
> dependencies. .....
>   Depends: libgcc1 (>=1:4.0.2) but 1:4.0.1-4ubuntu9 will be installed
>   Depends: libgeos2c2a  but it is not installable
>   Depends: libstdc++6 (>=4.0.2-4) but 4.0.1-4ubuntu9 will be installed
> And after that just a "close"-button
> So maybe my problem really is the lack of libgeos2c2a???
> /Regards Mikael
> On Mar 7, 2006, at 10:30 AM, Mikael Schröder wrote:
> > Hi all!
> > I followed this thread and read every thing I could find on the
> > matter, but when I try to add the PostGIS 8.1 deb from within
> > Synaptic in Breezy, Synaptic complains about wrong version of
> > libstdc (4.0.1 instead of 4.0.2) and consequently libgeos2c2. How
> > can I handle this problem without compiling from source or changing
> > to next version of libstdc wich I understand to be a bit
> > bothersome. Does anyone have a different pkg for breezy?
> > /Mikael
> > >I appreciate your help, but I think you are working in unstable
> > with >libstdc++ 4.02 and I'm in Breezy with libstdc++4.01.  If
> > Blair can fix >his pkg then that gives Breezy users both postgresql
> > 8.1 & postgis.
> What issue are you seeing?  The packages I built are only built
> against Breezy's packages.  I make all the packages I built available
> in my site, so there shouldn't be any dependencies that are not
> fullfilled.
> Also, shouldn't 4.01 and 4.02 be binary compatible?
> Regards,
> Blair
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20060307/02cc827f/attachment.html>
