[postgis-users] box3d
Jürgen Mischker juergen.mischker at boku.ac.at
Tue Mar 14 23:31:08 PST 2006
Today I turned t back to my box3d problem: the odd thing is that I do not recive the error message again. (maybe I should check with my admin).
Sorry keeping you busy...
The only strange thing is that I tried another query (workaround) , which should do the same thing, but with different results:
select count(*) from laserjosef
WHERE the_geom && GeomFromText('POLYGON((-589213 -1149204, -589213 -1149104, -589113 -1149104, -589113 -1149204, -589213 -1149204))',-1)
AND distance(the_geom, GeomFromText('POINT(-589163 -1149154)',-1)) < 50;
Result: 18773 rows
WHERE the_geom && 'BOX3D(-589213 -1149204, -589113 -1149104)'::box3d
Result: 45157 rows
Did i missed something???
schabi at logix-tt.com wrote on 14.03.2006 18:15:41:
> Hi, Jürgen,
> Jürgen Mischker wrote:
>> BUT:
>> ... 'BOX3D(90900 190900, 100100 200100)'::box3d...
>> doesn`t work:
>> ERROR: BOX3D parser - doesnt start with BOX3d(
> Which PostGIS / PostgreSQL version are you using? I cannot reproduce it
> here:
> navteq=# select 'BOX3D(90900 190900, 100100 200100)'::box3d;
>                  box3d
>  BOX3D(90900 190900 0,100100 200100 0)
> (1 row)
> And grepping throug the current source, I cannot find the String "BOX3d"
> but I can see
> ./lwgeom/lwgeom_box3d.c: elog(ERROR,"BOX3D parser - doesnt start with
> BOX3D(");
> So I assume you've got a case sensitivity problem here.
> Btw, why don't you use box2d:
> navteq=# select 'BOX(90900 190900, 100100 200100)'::box2d;
>               box2d
>  BOX(90900 190900,100100 200100)
> (1 row)
> HTH,
> Markus
> Markus Schaber | Logical Tracking&Tracing International AG
> Dipl. Inf.     | Software Development GIS
> Fight against software patents in EU! www.ffii.org
> www.nosoftwarepatents.org
> postgis-users mailing list
