[postgis-users] Mapserver and Postgis
Ezequias Rodrigues da Rocha ezequias at recife.pe.gov.br
Wed Mar 29 04:23:30 PST 2006
Obe, Regina DND\MIS escreveu:
> Were you able to try psql from the webserver?
here network 10 (with -h parameter) and in the webserver machine
> What network is your webserver on?
network 192
> What network is your database server on?
> What network is your local pc on?
network 10
> I just want to rule out the issue of your database server and
> workstation  is on a private network (192.168....) so they can see each
> other, but your webserver is on a public network 200..... Etc.  Because
> that definitely will not work.  A Private ip can never be accessed
> except by a computer on that same private network.  I know its obvious
> but just wanted to state the obvious.
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net]
> Sent: Wednesday, March 29, 2006 6:53 AM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] Mapserver and Postgis
>> Is that machine your workstation or the webserver?  If its not the
>> webserver, then are you able to do the same test when logged in on the
>> webserver?
> This is my machine. I am using the -h option to connect to a webserver.
>> What does  your pg_hba.conf on your postgresql server look like?  This
>> by default is in the data directory of your postgresql server.  As
>> Gregory mentioned this controls what computers are allowed to connect
>> to the postgresql daemon.
> My pg_hba.conf
> # TYPE  DATABASE    USER        CIDR-ADDRESS          METHOD
> # "local" is for Unix domain socket connections only
> local   all         all                               trust
> # IPv4 local connections:
> host    all         all         10.0.0.0 255.0.0.0    password
> host    all         all         172.0.0.0 255.0.0.0       password
> host    all         all         192.168.0.0 255.0.0.0 password
> host    all         all         127.0.0.1/32          trust
> host    all         all         200.249.133.135 255.255.255.255
> password
> # IPv6 local connections:
> host    all         all         ::1/128               trust
> host    all         all         192.168.0.0 255.255.0 0 password
> That's it.
>> Sent: Tuesday, March 28, 2006 11:50 AM
>> Obe,
>> Fortunately I have psql here in my machine and I tryed to connect
>> using it.
>> The connection was ok with your parameters psql -U postgres
>> machine.domainmachine db
>> Have you any suggestion ?
>> Ezequias
>>> Ezequias,
>>> Then I guess one thing to try would be connect into your webserver
>>> via ssh or some other means and then do a ping on your postgresql
> server.
>>> That may not work depending on whether pinging is blocked or not.
>>> If you had a psql client on the webserver or can easily put one on,
>>> then you can do more indepth analysis. With something like below
>>> psql -h myserver.mydomain.com mydb
>>> Also you said you logged in using ssh from your local computer to the
>>> postgresql server.  Did you try connecting to the postgresql server
>>> via the psql client from your local pc.  Just because you can ssh
> into
>>> the postgresql server doesn't necessarily mean postgres daemon is
>>> listening on a TCP/IP port.
>>> Sent: Tuesday, March 28, 2006 8:37 AM
>>> Yes, I have a root account on webserver.
>>> Best regards...
>>> Ezequias
>>>> It could be that your webserver doesn't allow outbound connections
>>>> on 5432 because it has a firewall in front blocking.  As Greg
>>>> mentioned it sounds like you aren't connecting at all.
>>>> Do you have root access to your webserver?
>>>> Sent: Tuesday, March 28, 2006 8:02 AM
>>>> Gregory,
>>>> Many thanks but there is notthing on the  postgresql-Tue.log :-( .
>>>> I can start and stop the postgresql without problem. I use
>>>> postmaster -D
>>>> way.
>>>> Another thing. How can I ping using mapserver ?
>>>> Another thing2:I can log to postgis using ssh connection (as root
>>>> and
>>>> after as postgres user). Another thing3:There is no password to
>>>> postgis ( linux )user. The postgis (database) user has yes a
> password
>>>> (and I used on the map
>>> file)
>>>> I hope  you could understand my enviroment.
>>>> Ezequias
>>>> Gregory S. Williamson escreveu:
>>>>> Ezequias --
>>>>> What does the postgres log say ? That's a good place to start
>>>>> debugging this.
>>>>> The text that you quoted has several very good suggestions;
>>>>> assuming
>>>>> that the connection string seems rational to you, i.e. user,
>>> password,
>>>>> server and database are all sane, I would suggest making sure that
>>>>> you
>>>>> can can ping the postgres server from the mapserver ... if so
>>>>> Check the postgres log and see if it is refusing the connection. if
>>>>> it
>>>>> is you need to add the postgres user (not a great idea to exposte
>>>>> the DBA account as a working account, but that's another issue) and
>>>>> the
>>> IP
>>>>> address to the .hba file on the postres server. That file controls
>>>>> who
>>>>> can connect and can't; it is in the root of the directory the
>>>>> postgres
>>>>> database was created in.
>>>>> If there is nothing in the log I'd suspect the TCP issue, or some
>>>>> routing issue since postgres will write a useful message if an
>>>>> un-authorized user tries to connect. Presumably the postgres user
>>>>> has
>>>>> permissions to connect to the database and access the tables.
>>>>> It is possible the postgres instance was not started with the
>>>>> proper
>>>>> to allow TCP/IP connections; that is controlled by the script that
>>>>> starts the postgres database. I'm not sure if the error log would
>>> show
>>>>> anything in this case.
>>>>> HTH, post back your results and maybe others can help more.
>>>>> Greg Williamson
>>>>> DBA
>>>>> GlobeXplorer LLC
>>>>> From:	postgis-users-bounces at postgis.refractions.net on behalf
>>> of
>>>>> Sent:	Tue 3/28/2006 4:35 AM
>>>>> Cc:
>>>>> Subject:	[postgis-users] Mapserver and Postgis
>>>>> Hi list,
>>>>> I don't know if this is a off-topic, but as nobody from mapserver
>>>>> could solve my problem I will report to you now.
>>>>> I am trying to connect my mapserver project to PostGIS but my
>>>>> browser
>>>>> always report the folowing error:
>>>>> msDrawMap(): Image handling error. Failed to draw layer named
>>>> 'bairros'.
>>>>> msPOSTGISLayerOpen(): Query error. couldnt make connection to DB
>>>>> with connect string 'user=postgres password=***** dbname=db
>>>>> host=xxx.xxx port=5432'. Error reported was 'could not create
>>>>> socket: Permission denied '. This error occured when trying to make
>>>>> a connection to the specified postgresql server.
>>>>> Most commonly this is caused by
>>>>> (1) incorrect connection string
>>>>> (2) you didnt specify a 'user=...' in your connection string
>>>>> (3) the postmaster (postgresql server) isnt running
>>>>> (4) you are not allowing TCP/IP connection to the postmaster
>>>>> (5) your postmaster is not running on the correct port - if its not
>>> on
>>>>> 5432 you must specify a 'port=...'
>>>>> (6) the security on your system does not allow the webserver
>>>>> (usually user 'nobody') to make socket connections to the
> postmaster
>>>>> (7) you forgot to specify a 'host=...' if the postmaster is on a
>>>>> different machine
>>>>> (8) you made a typo
>>>>> Could someone help me. As simple as possible would be very glad.
>>>>> Sincerely...
http://ezequiasrocha.blogspot.com
msn:ezequias at hotmail.com
"the worst of democracies is still better than the best of dictatorship"
