[postgis-users] Mapserver and Postgis
Ezequias Rodrigues da Rocha ezequias at recife.pe.gov.br
Wed Mar 29 04:53:17 PST 2006
The webserver and postgis server is the same. They are on the network 192.
I just think, too , there is a firewall between the two networks.
I can connect to postggis via ssh but not via mapserver (script cgi). I
really don't know who is trying to connect to PostGIS when we run a URL
via browser to mapserver.
Obe, Regina DND\MIS escreveu:
> The lines below got a bit scramled so let me restate my understanding
> 1) You were able to connect to the database via your webserver with psql
> and it was successful e.g. you saw the psql prompt and can run a select
> statement.
> 2) Your local pc is on network 10. , your database server is on 192
> (I'm assuming if this is correct you've got some sort of routing going
> on between your 10 and 192 networks)
> 3) What network is your webserver on 10?
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net]
> Sent: Wednesday, March 29, 2006 7:24 AM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] Mapserver and Postgis
>> Were you able to try psql from the webserver?
> here network 10 (with -h parameter) and in the webserver machine
>> What network is your webserver on?
> network 192
>> What network is your database server on?
>> What network is your local pc on?
> network 10
>> I just want to rule out the issue of your database server and
>> workstation  is on a private network (192.168....) so they can see
>> each other, but your webserver is on a public network 200..... Etc.
>> Because that definitely will not work.  A Private ip can never be
>> accessed except by a computer on that same private network.  I know
>> its obvious but just wanted to state the obvious.
>> Sent: Wednesday, March 29, 2006 6:53 AM
>>> Is that machine your workstation or the webserver?  If its not the
>>> webserver, then are you able to do the same test when logged in on
> the
>>> webserver?
>> This is my machine. I am using the -h option to connect to a
>> webserver.
>>> What does  your pg_hba.conf on your postgresql server look like?
>>> This
>>> by default is in the data directory of your postgresql server.  As
>>> Gregory mentioned this controls what computers are allowed to connect
>>> to the postgresql daemon.
>> My pg_hba.conf
>> # TYPE  DATABASE    USER        CIDR-ADDRESS          METHOD
>> # "local" is for Unix domain socket connections only
>> local   all         all                               trust
>> # IPv4 local connections:
>> host    all         all         10.0.0.0 255.0.0.0    password
>> host    all         all         172.0.0.0 255.0.0.0       password
>> host    all         all         192.168.0.0 255.0.0.0 password
>> host    all         all         127.0.0.1/32          trust
>> host    all         all         200.249.133.135 255.255.255.255
>> password
>> # IPv6 local connections:
>> host    all         all         ::1/128               trust
>> host    all         all         192.168.0.0 255.255.0 0 password
>> That's it.
>>> Sent: Tuesday, March 28, 2006 11:50 AM
>>> Obe,
>>> Fortunately I have psql here in my machine and I tryed to connect
>>> using it.
>>> The connection was ok with your parameters psql -U postgres
>>> machine.domainmachine db
>>> Have you any suggestion ?
>>> Ezequias
>>>> Ezequias,
>>>> Then I guess one thing to try would be connect into your webserver
>>>> via ssh or some other means and then do a ping on your postgresql
>> server.
>>>> That may not work depending on whether pinging is blocked or not.
>>>> If you had a psql client on the webserver or can easily put one on,
>>>> then you can do more indepth analysis. With something like below
>>>> psql -h myserver.mydomain.com mydb
>>>> Also you said you logged in using ssh from your local computer to
>>>> the postgresql server.  Did you try connecting to the postgresql
>>>> server via the psql client from your local pc.  Just because you can
>>>> ssh
>> into
>>>> the postgresql server doesn't necessarily mean postgres daemon is
>>>> listening on a TCP/IP port.
>>>> Sent: Tuesday, March 28, 2006 8:37 AM
>>>> Yes, I have a root account on webserver.
>>>> Best regards...
>>>> Ezequias
>>>>> It could be that your webserver doesn't allow outbound connections
>>>>> on 5432 because it has a firewall in front blocking.  As Greg
>>>>> mentioned it sounds like you aren't connecting at all.
>>>>> Do you have root access to your webserver?
>>>>> Sent: Tuesday, March 28, 2006 8:02 AM
>>>>> Gregory,
>>>>> Many thanks but there is notthing on the  postgresql-Tue.log :-( .
>>>>> I can start and stop the postgresql without problem. I use
>>>>> postmaster -D
>>>>> way.
>>>>> Another thing. How can I ping using mapserver ?
>>>>> Another thing2:I can log to postgis using ssh connection (as root
>>>>> and
>>>>> after as postgres user). Another thing3:There is no password to
>>>>> postgis ( linux )user. The postgis (database) user has yes a
>> password
>>>>> (and I used on the map
>>>> file)
>>>>> I hope  you could understand my enviroment.
>>>>> Ezequias
>>>>> Gregory S. Williamson escreveu:
>>>>>> Ezequias --
>>>>>> What does the postgres log say ? That's a good place to start
>>>>>> debugging this.
>>>>>> The text that you quoted has several very good suggestions;
>>>>>> assuming
>>>>>> that the connection string seems rational to you, i.e. user,
>>>> password,
>>>>>> server and database are all sane, I would suggest making sure that
>>>>>> you
>>>>>> can can ping the postgres server from the mapserver ... if so
>>>>>> Check the postgres log and see if it is refusing the connection.
>>>>>> if
>>>>>> it
>>>>>> is you need to add the postgres user (not a great idea to exposte
>>>>>> the DBA account as a working account, but that's another issue)
>>>>>> and
>>>>>> the
>>>> IP
>>>>>> address to the .hba file on the postres server. That file controls
>>>>>> who
>>>>>> can connect and can't; it is in the root of the directory the
>>>>>> postgres
>>>>>> database was created in.
>>>>>> If there is nothing in the log I'd suspect the TCP issue, or some
>>>>>> routing issue since postgres will write a useful message if an
>>>>>> un-authorized user tries to connect. Presumably the postgres user
>>>>>> has
>>>>>> permissions to connect to the database and access the tables.
>>>>>> It is possible the postgres instance was not started with the
>>>>>> proper
>>>>>> to allow TCP/IP connections; that is controlled by the script that
>>>>>> starts the postgres database. I'm not sure if the error log would
>>>> show
>>>>>> anything in this case.
>>>>>> HTH, post back your results and maybe others can help more.
>>>>>> Greg Williamson
>>>>>> DBA
>>>>>> GlobeXplorer LLC
>>>>>> From:	postgis-users-bounces at postgis.refractions.net on behalf
>>>> of
>>>>>> Sent:	Tue 3/28/2006 4:35 AM
>>>>>> Cc:
>>>>>> Subject:	[postgis-users] Mapserver and Postgis
>>>>>> Hi list,
>>>>>> I don't know if this is a off-topic, but as nobody from mapserver
>>>>>> could solve my problem I will report to you now.
>>>>>> I am trying to connect my mapserver project to PostGIS but my
>>>>>> browser
>>>>>> always report the folowing error:
>>>>>> msDrawMap(): Image handling error. Failed to draw layer named
>>>>> 'bairros'.
>>>>>> msPOSTGISLayerOpen(): Query error. couldnt make connection to DB
>>>>>> with connect string 'user=postgres password=***** dbname=db
>>>>>> host=xxx.xxx port=5432'. Error reported was 'could not create
>>>>>> socket: Permission denied '. This error occured when trying to
>>>>>> make
>>>>>> a connection to the specified postgresql server.
>>>>>> Most commonly this is caused by
>>>>>> (1) incorrect connection string
>>>>>> (2) you didnt specify a 'user=...' in your connection string
>>>>>> (3) the postmaster (postgresql server) isnt running
>>>>>> (4) you are not allowing TCP/IP connection to the postmaster
>>>>>> (5) your postmaster is not running on the correct port - if its
>>>>>> not
>>>> on
>>>>>> 5432 you must specify a 'port=...'
>>>>>> (6) the security on your system does not allow the webserver
>>>>>> (usually user 'nobody') to make socket connections to the
>> postmaster
>>>>>> (7) you forgot to specify a 'host=...' if the postmaster is on a
>>>>>> different machine
>>>>>> (8) you made a typo
>>>>>> Could someone help me. As simple as possible would be very glad.
>>>>>> Sincerely...
http://ezequiasrocha.blogspot.com
msn:ezequias at hotmail.com
"the worst of democracies is still better than the best of dictatorship"
