[postgis-users] adding additional points to multipoint
Christo Du Preez christo at mecola.com
Fri Mar 31 02:57:32 PST 2006
Thank you,
When trying
update meclabel
set the_geom = geomunion(the_geom, GeomFromText('POINT(23 4)', -1))
I get:: ERROR:  new row for relation "meclabel" violates check
constraint "enforce_geotype_the_geom"
This is how my table looks? Do I have to cast the result of geomunion?
-- Table: meclabel
-- DROP TABLE meclabel;
CREATE TABLE meclabel
  gid int4 NOT NULL DEFAULT nextval('meclabel_gid_seq'::regclass),
  name text,
  "type" text,
  "class" text,
  angle float4,
  refgid int4,
  x float4,
  y float4,
  the_geom geometry,
  CONSTRAINT meclabel_pkey PRIMARY KEY (gid),
  CONSTRAINT enforce_dims_the_geom CHECK (ndims(the_geom) = 2),
  CONSTRAINT enforce_geotype_the_geom CHECK (geometrytype(the_geom) =
'MULTIPOINT'::text OR the_geom IS NULL),
  CONSTRAINT enforce_srid_the_geom CHECK (srid(the_geom) = -1)
WITHOUT OIDS;
ALTER TABLE meclabel OWNER TO postgres;
-- Index: meclabel_gist_the_geom
-- DROP INDEX meclabel_gist_the_geom;
CREATE INDEX meclabel_gist_the_geom
  ON meclabel
  USING gist
  (the_geom);
Markus Schaber wrote:
> Hi, Christo,
> Christo Du Preez wrote:
>> How do I add an additional point to a multipoint geometry in an update
>> statement?
> select asText(geomunion('MULTIPOINT(1 1,3 3)','POINT(2 2)'));
>          astext
>  MULTIPOINT(1 1,2 2,3 3)
> (1 row)
> So you can
>   UPDATE geocolumn = geomunion(geocolumn,'YOURPOINT') WHERE condition;
> However, note that you don't have any influence on the ordering of the
> points in the resulting multipoint, it depends on the internal geometry
> indexing in geomunion.
> Strk, maybe we should allow addpoint() to work with multipoints, too?
> Or as alternative, add an "addgeom(collection, geometry)" that adds a
> geometry to a MULTI*/GeometryCollection?
> HTH,
> Markus
Kind Regards,
Christo Du Preez
Senior Software Engineer
Mecola IT
http://www.mecola.com
+27 [0]83 326 8087
