[postgis-users] points in polygon
Josh Livni josh at livniconsulting.com
Fri Mar 31 14:17:39 PST 2006
This does not answer your question of speedy spatial calcuation, but
assuming your points are fairly static, you could add a field like
in_polygon, run for all points, index on that field, and query on that,
saving you from needing to run the spatial query each time.
If you get new points, you could have a couple queries, running the
spatial one just on those with no set value in that field.
I know it's hackish, and again not a direct answer to your question, but
I find pre-calculating on mostly static datasets gets me a great boost
in speed for many scenarios.
Regards,
   -Josh
Young Kim wrote:
> thanks all for your responses.
> the solution that you all provided did work, but my main problem is
> that i need the query to run FAST.
> BOX, WITHIN and INTERSECTS all runs in 140000~170000 ms ranges.
> I tried with smaller cities, and they run in good time.
> "santa monica" runs in 130 ms.
> Is it then the area that i'm joining against is too large or too complex?
> With all the gist indices on "the_geom" columns in place and "vacuum
> analyze" run, I would think it should not take 3 minuts to run a
> query.
> On 3/31/06, Bruce Rindahl <rindahl at lrcwe.com> wrote:
>>I don't this is even that complicated.
>>Try
>>SELECT  point.id
>>FROM    point, polygon
>>WHERE   (polygon.fips = '0644000')
>>       AND point.the_geom && polygon.the_geom
>>       AND intersects(polygon.the_geom, point.the_geom);
>>The first clause checks for only LA county.
>>The next clause checks if the bounding box of the point is within the
>>bounding box of the polygon.  (very fast if the GIST indexes are set)
>>Finally anything that matches the first two is checked for an actual
>>intersection.
>>Bruce Rindahl
>>-----Original Message-----
>>From: postgis-users-bounces at postgis.refractions.net
>>[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
>>Matthew Perry
>>Sent: Friday, March 31, 2006 12:03 PM
>>To: PostGIS Users Discussion
>>Subject: Re: [postgis-users] points in polygon
>>Perhaps you can try WITHIN instead of CONTAINS?
>>Within(geometry A, geometry B)
>>    Returns 1 (TRUE) if Geometry A is "spatially within" Geometry B.
>>- matt
>>On 3/31/06, Young Kim <youngkkim at gmail.com> wrote:
>>>Thanks for your prompt response.
>>>I have tried :
>>>SELECT  point.id
>>>FROM    point, polygon
>>>      and point.the_geom && SetSRID('BOX3D(-118.668411254883
>>>33.7045364379883,-117.753349304199 34.3367500305176)'::box3d,-1)
>>>          AND (contains(polygon.the_geom, point.the_geom));
>>>got ~146000ms.
>>>could not get "makebox2d" to work. syntax errors. i'm very new to
>>postgis.
>>>thanks.
>>>On 3/31/06, David Bitner <osgis.lists at gmail.com> wrote:
>>>>Have you tried creating a bounding box out of the x, y pair you are
>>>>using and then using the && operator on that rather than using the
>>>>x>,y> statements.
>>>>See MakeBox2D in http://postgis.refractions.net/docs/ch06.html
>>>>>hello all,
>>>>>looking to select points in a polygon FAST. Seems like a simple
>>>>>problem, but could not find good doc anywhere.
>>>>>Thanks in advance.
>>>>>BACKGROUND:
>>>>>points - 8663 points in greater los angeles area.
>>>>>          - has "gist" index on "the_geom"
>>>>>polygon - city of los angeles
>>>>>            - has "btree" index on "fips"
>>>>>also ran "vaccum analyze"
>>>>>PROBLEM:
>>>>>looking to select all points in city of los angeles.
>>>>>out of 8663, 3248 points are contained in city of los angeles
>>polygon.
>>>>>it takes ~163000 ms. that's roughly 3 minutes.
>>>>>How can I make this faster?
>>>>>QUERY (x,y values are extent of polygon):
>>>>>SELECT   point.id
>>>>>FROM      point, polygon
>>>>>WHERE   (x >= -118.668411254883)
>>>>>       AND (y >= 33.7045364379883)
>>>>>       AND (x <= -117.753349304199)
>>>>>       AND (y <= 34.3367500305176)
>>>>>       AND (polygon.fips = '0644000')
>>>>> Aggregate  (cost=9.08..9.09 rows=1 width=4) (actual
>>>>>time=162893.411..162893.411 rows=1 loops=1)
>>>>>   ->  Nested Loop  (cost=0.00..9.05 rows=9 width=4) (actual
>>>>>time=4137.275..162885.507 rows=3248 loops=1)
>>>>>         Join Filter: contains("outer".the_geom, "inner".the_geom)
>>>>>         ->  Index Scan using idx_polygon_fips on polygon
>>>>>(cost=0.00..3.01 rows=1 width=9414) (actual time=0.013..0.017
>>rows=1
>>>>>loops=1)
>>>>>               Index Cond: ((fips)::text = '0644000'::text)
>>>>>         ->  Index Scan using idx_point_the_geom on point
>>>>>(cost=0.00..6.02 rows=1 width=25) (actual time=62.512..17889.149
>>>>>rows=7050 loops=1)
>>>>>               Index Cond: (point.the_geom && "outer".the_geom)
>>>>>               Filter: ((point.x >= -118.668411254883) AND
>>(point.y >=
>>>>>33.7045364379883) AND (point.x <= -117.753349304199) AND (point.y
>>>>>34.3367500305176) AND (point.the_geom && "outer".the_geom))
>>>>> Total runtime: 162893.483 ms
>>>>>_______________________________________________
>>>>>postgis-users mailing list
>>>>>postgis-users at postgis.refractions.net
>>>>>http://postgis.refractions.net/mailman/listinfo/postgis-users
>>Matt Perry
>>perrygeo at gmail.com
>>http://www.perrygeo.net
