[postgis-users] Re: Status of geocoding functions in PostGIS?
javaguru at bellsouth.net javaguru at bellsouth.net
Fri Mar 31 20:53:45 PST 2006
Hello Dan,
Jamaica is divided up into 13 parishes and each parish has its own shapefile, which varies slightly from the other; however, all the necessary info is there.  Here's the output of ogrinfo for the Manchester parish:
Layer name: Manchester_rd
Geometry: Line String
Feature Count: 8876
Extent: (682982.937500, 632664.250000) - (712562.750000, 678018.625000)
Layer SRS WKT:
PROJCS["WGS_1984_Lambert_Conformal_Conic",
    GEOGCS["GCS_WGS_1984",
        DATUM["WGS_1984",
            SPHEROID["WGS_1984",6378137.0,298.257223563]],
        PRIMEM["Greenwich",0.0],
        UNIT["Degree",0.0174532925199433]],
    PROJECTION["Lambert_Conformal_Conic_2SP"],
    PARAMETER["False_Easting",750000.0],
    PARAMETER["False_Northing",650000.0],
    PARAMETER["Central_Meridian",-77.0],
    PARAMETER["Standard_Parallel_1",18.0],
    PARAMETER["Standard_Parallel_2",18.00000027777778],
    PARAMETER["Latitude_Of_Origin",18.0],
    UNIT["Meter",1.0]]
FNODE_: Integer (9.0)
LENGTH: Real (19.11)
L_F_ADD: String (10.0)
L_T_ADD: String (10.0)
R_F_ADD: String (10.0)
R_T_ADD: String (10.0)
STREET_NAM: String (50.0)
STREET_TYP: String (5.0)
CLASS: String (3.0)
PARISHL: String (1.0)
PARISHR: String (1.0)
CATEGORY: String (9.0)
SURFACE: String (7.0)
PARISH: String (13.0)
DISTRICT: String (30.0)
SCHEME_NAM: String (30.0)
SEGMENT_LE: Integer (9.0)
Seg_Num: Integer (2.0)
If you need any more info please let me know!  I also have a lot of data for both Brazil and Argentina (~5GB per country) that I have yet to look at.  In addition to that, I have the entire Australian road network, but it is in some sort of data format I am unfamilar with.  Can't think of it right now, but I'll try to remember to take a look again.
Regards,
Mark
P.S.  I also have a compiled list of the mapping agencies for most of the countries in the world.  I'm sure you'd probably be interested in that!
Date: 2006/03/31 Fri PM 10:07:43 CST
To: javaguru at ieee.org,
        PostGIS Users Discussion <postgis-users at postgis.refractions.net>
Subject: Re: [postgis-users] Re: Status of geocoding functions in PostGIS?
Hi Mark,
Something outside of the US and Canada would be great. The Jamaica
file works, the Trinidad and Tobago doesn't. Without address ranges a
traditional postal address geocoder needs that information to function.
In terms of collaborating with Paul Smith and the PostGIS geocoder
project, I think it makes perfect sense. After the response I made to
Steve Woodbridge's post this morning, I kicked myself for not
explicitly indicating that the group which is the natural one to
mutually provide helping hands to one another in developing a library
to create a Postgres stored procedure of postal address geocoding.
Dan
On 31-Mar-06, at 7:01 PM, Mark Thomas wrote:
> Dan,
> I have access to a spatial road network for Jamaica and a partial
> road network (no street numbers) for trinidad & tobago, so perhaps
> the structures of these addresses would be helpful to you.  I'm
> afraid I cannot release the data as it belongs to the Jamaican and
> Trinidad governments, respectively, but I could copy the structure
> of the shapefiles for you.  I would also like to look into helping
> out on your project and possibly Paul's as well.  I think this
> would be a good opportunity to join the two projects and begin
> collaborating with each other to speed up development.
> I also have extensive experience in reverse geocoding and am
> looking into writing a country agnostic reverse geocoder.  I have
> implemented this in Java and PL/SQL for Oracle Spatial for the US
> so far, but I am considering porting it to PostGIS; however, the
> major roadblock for me is the lack of a nearest neighbor query
> function in PostGIS.  If anyone knows of an implementation please
> let me know as the migration from PL/SQL to PL/PGSQL would be quite
> trivial at that point.
> Mark Thomas
> Sun Certified Java 5 Programmer
> Sun Certified Java 2 Programmer
> Sun Certified Web Component Developer
> postgis-users mailing list
Mark Thomas
205.529.9013
