[postgis-users] Help with GPS Coord in PostGIS
Tyler Mitchell tylermitchell at shaw.ca
Thu May 11 12:20:24 PDT 2006
Hi David,
I think you have your latitude (y) and longitude (x) mixed up in the database!  Hopefully that is all that it is.  It's a common problem because we say "latitude" first and use "x" first in EXTENT settings.
Tyler
----- Original Message -----
Date: Thursday, May 11, 2006 11:58 am
Subject: [postgis-users] Help with  GPS Coord in PostGIS
> Hi All
> I have a project where I need to import a GPS File (a simple txt file)
> which contains think like:
> Fahrer
> A,133840.00,5407.4270,N,01038.0983,E,1,07,1.26,00036,M,045,M,,,44Fahrer A,133850.00,5407.4266,N,01038.0988,E,1,07,1.26,00033,M,045,M,,,4C
> Fahrer
> A,133900.00,5407.4265,N,01038.0989,E,1,07,1.27,00032,M,045,M,,,4AFahrer A,133910.00,5407.4265,N,01038.0989,E,1,07,1.27,00032,M,045,M,,,4B
> Fahrer
> A,133920.00,5407.4265,N,01038.0989,E,1,07,1.27,00031,M,045,M,,,4BFahrer A,134500.00,5407.4274,N,01038.0978,E,1,07,1.31,00037,M,045,M,,,4D
> into a postgis table
> CREATE TABLE gps_coord(
> "FAHRER" text ,
> "UTC" text ,
> latitude double precision ,
> "N/S" text ,
> longitude double precision ,
> "E/W" text ,
> "QUALITY" text ,
> "#SATELLITES" text ,
> "HDOP" text ,
> "ANTENNA ALTITUDE" text ,
> "M" text ,
> "GEO SEPERATION" text ,
> "M " text ,
> "QUALITDATA" text ,
> "DRS ID" text ,
> "CHECKSUM" text
> then
> longitude and latitude are in
>    degrees/minutes
> select addgeometrycolumn('gps_coord','the_geom',4326,'POINT',2);
> First of all I'm not really sure for the srid to use with 4326
> I have the formula in order to have the
> update  gps_coord set
> the_geom=geometryfromtext('POINT('||(latitude/100)::int+(latitude-
> 5400)/60||''||(longitude/100)::int+(longitude-1000)/60||')',4326) ;
> select x(the_geom),y(the_geom) from gps_coord limit 6;
>        x         |        y
> 54.1237833333333 | 10.6349716666667
> 54.1237766666667 |         10.63498
>        54.123775 | 10.6349816666667
>         54.12379 | 10.6349633333333
> What I want to know is that did I am doing something wrong? A mistake?
> With MapServer I got nothing on my picture...
> Thanks for help
> # DEBUT DE LA MAPFILE
> MAP
> #  EXTENT 10.5956216 54.0569046 10.8584151 54.1410554
> #EXTENT 54.0659713745117 10.6110792160034 54.1319885253906
> 11.8429574966431EXTENT 10.6110792160034 54.0659713745117
> 11.8429574966431 54.1319885253906
>  FONTSET "../etc/fonts.txt"
>  IMAGECOLOR 125 125 125
>  IMAGETYPE png
>  SYMBOLSET "../etc/symbols.sym"
>  SIZE 680 371
>  UNITS DD
>  STATUS ON
>  NAME "testgis"
> #  - symbole dash -
> SYMBOL
>  NAME "dash"
>  TYPE ELLIPSE
>  POINTS 1 1 END
>  FILLED TRUE
>  STYLE 10 5 5 10 END
> END
> # - symbole line-vertical -
> SYMBOL
>  NAME "line-vertical"
>  TYPE vector
>  POINTS
>    0.5 0
>    0.5 1
>  END
> END
> # - symbole line-horizontal -
> SYMBOL
>  NAME "line-horizontal"
>  TYPE vector
>  POINTS
>    0 0.5
>    1 0.5
>  END
> END
>  QUERYMAP
>      COLOR 255 255 0
>    SIZE -1 -1
>    STATUS OFF
>    STYLE HILITE
>  END
> # - WEB -
>  WEB
>    IMAGEPATH "/var/www/tutorial/tutorial/tmp/"
>    IMAGEURL "/tutorial/tutorial/tmp/"
>      METADATA
>      END
>    QUERYFORMAT text/html
>  END
> # MakeLine() -
>  LAYER
>    CONNECTION "user=david dbname=testgis host=localhost"
>    CONNECTIONTYPE POSTGIS
>    DATA "makeline from (select makeline(the_geom),1 as gid from
> gps_coord) as foo USING UNIQUE gid USING SRID=4326"
> #  LABELITEM "gid"
>      METADATA
>      END
>    NAME "buildings"
>    SIZEUNITS PIXELS
>    STATUS ON
>    TOLERANCE 0
>    TOLERANCEUNITS PIXELS
>    TYPE LINE
>    CLASS
>      METADATA
>      END
>      STYLE
>        ANGLE 360
>          OUTLINECOLOR 80 80 80
>        SIZE 10
>        SYMBOL "circle"
>      END
>    END
>  END
> # FIN DE LA MAPFILE
> END
> ___________________________________________________________________________
> Yahoo! Mail réinvente le mail ! Découvrez le nouveau Yahoo! Mail
> et son interface révolutionnaire.
> http://fr.mail.yahoo.com
> postgis-users mailing list
