[postgis-users] snap2geom
Christo Du Preez christo at mecola.com
Thu Nov 2 03:59:03 PST 2006
This is waaayyyy over my head. How do I go about doing this and what is
the function called you're referring too?
strk at refractions.net wrote:
> On Wed, Nov 01, 2006 at 07:36:59AM +0200, Christo Du Preez wrote:
>> Hi All,
>> Is there a function or something I can use to snap multiple geoms
>> [polygons] together so that there borders match. I want to use this
>> after I've simplified my geoms.
> This sounds an useful one... You might try exposing this functionality
> in the GEOS C-API as GEOS-3.0.0 provides it internally. Once it's
> in the C-API it will easily be used by postgis.
> --strk;
> postgis-users mailing list
Christo Du Preez
Senior Software Engineer
Mecola IT
+27 [0]83 326 8087
