[postgis-users] Further PostGIS / GEOS problems
Nick Black nickblack1 at gmail.com
Thu Nov 2 07:20:16 PST 2006
Hello,
Thanks to some help from this list and #postgis, I have diagnosed the
problem with GEOS that I described earlier.
So now I am trying to compile postgis, with this configure option:
 ./configure --prefix=/usr --with-pgsql=/usr/bin/pg_config
--with-geos=/usr/bin/geos-config --with-proj=/usr
Which give this error:
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking for g++... no
checking for c++... no
checking for gpp... no
checking for aCC... no
checking for CC... no
checking for cxx... no
checking for cc++... no
checking for cl... no
checking for FCC... no
checking for KCC... no
checking for RCC... no
checking for xlC_r... no
checking for xlC... no
checking whether we are using the GNU C++ compiler... no
checking whether g++ accepts -g... no
checking whether ln -s works... yes
checking for iconv_open in -liconv... no
checking for libiconv_open in -liconv... no
checking for iconv_open in -lc... yes
checking how to run the C preprocessor... gcc -E
checking for egrep... grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking iconv.h usability... yes
checking iconv.h presence... yes
checking for iconv.h... yes
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking for geos-config... /usr/bin/geos-config
Usage: geos-config [OPTIONS]
Options:
     [--prefix]
     [--version]
     [--libs]
     [--cflags]
     [--includes]
     [--jtsport]
checking for proj... /usr/bin/proj
checking for flex... /usr/bin/flex
checking for dllwrap... no
checking for dlltool... no
checking for bison... bison -y
checking for perl... /usr/bin/perl
checking for xsltproc... /usr/bin/xsltproc
checking for pdfxmltex... no
checking for db2pdf... no
checking for jw... no
checking which template to use... linux
configure: creating ./config.status
config.status: creating Makefile.config
config.status: creating config.h
config.status: config.h is unchanged
 SUMMARY
 HOST_OS: linux-gnu
   PGSQL: /usr/bin/pg_config
    GEOS: /usr/bin/geos-config
          (ldflags: )
    PROJ: prefix=/usr libdir=/usr/lib
   ICONV: 1
 PORTNAME: linux
   PREFIX: /usr
  EPREFIX: ${prefix}
      DOC: ${prefix}/share/doc
     DATA: ${prefix}/share
      MAN: ${prefix}/man
      BIN: ${exec_prefix}/bin
      EXT: ${exec_prefix}/lib (${exec_prefix}/lib)
Seems that configure cant find g++ etc - which seems strange, as I can
compile other sources without problems.
I am running Ubuntu 6.06,  psql 8.1.4
Thanks again,
Nick
