[postgis-users] PostGIS Solaris problem
Svonja, Elvis Elvis.Svonja at sensis.com.au
Thu Nov 2 21:36:34 PST 2006
I have used GNU Make, and ensured the original one is removed from the
PATH. I also installed bison-1.875d
<ftp://ftp.sunfreeware.com/pub/freeware/intel/10/bison-1.875d-sol10-inte
l-local.gz> ,
However I'm now getting another Broken Pipe message with executing the
following Bison call:
bison -y -vd -p lwg_parse_yy wktparse.y
Full stack:
bash-3.00# make install
make -C lwgeom
make[1]: Entering directory `/da01/postgresql/gis/postgis-1.1.4/lwgeom'
sh ../geos_version.sh /usr/local > postgis_geos_version.h
make[1]: *** [wktparse.tab.c] Broken Pipe
make[1]: Leaving directory `/da01/postgresql/gis/postgis-1.1.4/lwgeom'
make: *** [liblwgeom] Error 2
Again, any suggestions are very much appreciated
Elvis
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Svonja, Elvis
Sent: Friday, 3 November 2006 3:27 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] PostGIS Solaris problem
Hi
I'm trying to install PostGIS on Solaris 10 (Sparc) without any success.
I have tried building it from the source, but I get an error:
make: Fatal error: Command failed for target `install'
I have installed all the dependant packages (i.e. geos, proj4,
libiconv).  I wasn't able to find anywhere a Solaris specific
installation archive or package of PostGIS. Any help would be much
appreciated.
Elvis
DETAILED ERROR MESSAGE:
Using GNU make found at /usr/local/bin/gmake
/usr/ccs/bin/yaccpar:5: warning: ignoring #pragma ident
/usr/ccs/bin/yaccpar: In function `lwg_parse_yyparse':
/usr/ccs/bin/yaccpar:164: warning: label `yynewstate' defined but not
used
/usr/ccs/bin/yaccpar:374: warning: label `yyerrlab' defined but not used
/usr/local/bin/flex -Plwg_parse_yy -i -f -o'lex.yy.c' wktparse.lex
flex: fatal internal error, exec failed
gmake[2]: *** [lex.yy.c] Broken Pipe
gmake[2]: *** Deleting file `lex.yy.c'
gmake[2]: Leaving directory `/da01/postgresql/gis/postgis-1.1.5/lwgeom'
gmake[1]: *** [liblwgeom] Error 2
gmake[1]: Leaving directory `/da01/postgresql/gis/postgis-1.1.5'
*** Error code 2
The following command caused the error:
IFS=':' ; \
 for dir in $PATH; do \
   for prog in gmake gnumake make; do \
     if [ -f $dir/$prog ] && ( $dir/$prog -f /dev/null --version
2>/dev/null | grep GNU >/dev/null 2>&1 ) ; then \
       GMAKE=$dir/$prog; \
       break 2; \
     fi; \
   done; \
 done; \
 if [ x"${GMAKE+set}" = xset ]; then \
   echo "Using GNU make found at ${GMAKE}"; \
   ${GMAKE} install ; \
 else \
   echo "You must use GNU make to build PostGIS." ; \
   false; \
 fi
Sensis. Australia's leading information resource.
Making complex lives simpler by helping you find, buy and sell.
www.about.sensis.com.au
www.sensis.com.au
www.yellow.com.au
www.whitepages.com.au
www.citysearch.com.au
www.whereis.com.au
www.gostay.com.au
www.justlisted.com.au
www.linkme.com.au
www.telstra.com.au
www.tradingpost.com.au
www.universalpublishers.com.au
www.invizage.com.au
Sensis cares for the environment - think before you print.
This email and any attachments are intended only for the use of the
recipient and may be confidential and/or legally privileged.
Sensis Pty Ltd disclaims liability for any errors, omissions, viruses,
loss and/or damage arising from using, opening or transmitting this
email.
If you are not the intended recipient you must not use, interfere with,
disclose, copy or retain this email and you should notify the sender
immediately by return email or by contacting Sensis Pty Ltd by telephone
on [+61 3 8653 5000]
www.sensis.com.au
www.yellow.com.au
www.whereis.com.au
www.gostay.com.au
www.linkme.com.au
www.telstra.com.au
www.invizage.com.au
This email and any attachments are intended only for the use of the recipient and may be confidential and/or legally privileged.
Sensis Pty Ltd disclaims liability for any errors, omissions, viruses, loss and/or damage arising from using, opening or transmitting this email.
If you are not the intended recipient you must not use, interfere with, disclose, copy or retain this email and you should notify the sender immediately by return email or by contacting Sensis Pty Ltd by telephone on [+61 3 8653 5000]
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20061103/c4019ac8/attachment.html>
