[postgis-users] Help with query
Stephen Woodbridge woodbri at swoodbridge.com
Fri Nov 3 13:14:45 PST 2006
Pedro,
In general there is no association between records in the database
unless you explicitly associate them. In fact two records that you
insert from process A might not actually be adjacent in the database if
other processes are inserting also.
So what you need to do is create a column like 'process_id' where
process_id is a unique identifier for a sequence of steps then you can
select all those records and order then by the timestamp and then you
can compute the time differences.
-Steve
Pedro Doria Meunier wrote:
> This is probably not the best place to be asking such a (lame) question
> but perhaps someone is gracious enough to lend me a hand… ;-)
> I have the following setup in a table:
> The first record which is to be found (ok easy enough :D) with a
> timestamp meets a certain condition (ignition off)
> The following record is for the event of ignition on again with a
> timestamp.
> So the question here is: how can I compute the time difference between
> these two records in a single query?
> Better yet: finding all the records that meet the first condition
> (ignition off) and the immediately following records as to compute the
> time difference. ;-)
> Thanks in advance!
> Pedro Doria Meunier
> (351) 91 302 49 72 - (351) 96 247 99 12
> MSN - pdoriam at hotmail.com <mailto:pdoriam at hotmail.com>
> ICQ - 308-182-126
> Skype: pdoriam
> postgis-users mailing list
