[postgis-users] Help with query
Paul Ramsey pramsey at refractions.net
Fri Nov 3 17:02:36 PST 2006
Ye gods, Regina, you're amazing.
On 3-Nov-06, at 2:14 PM, Pedro Doria Meunier wrote:
> Regina,
> You’re absolutely the GREATEST! It worked like a charm!
> Thank you VERY much!
> All the best,
> Pedro Doria Meunier
> (351) 91 302 49 72 - (351) 96 247 99 12
> MSN - pdoriam at hotmail.com
> ICQ - 308-182-126
> Skype: pdoriam
> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-
> users-bounces at postgis.refractions.net] On Behalf Of Obe, Regina
> Sent: sexta-feira, 3 de Novembro de 2006 21:04
> To: PostGIS Users Discussion
> Subject: RE: [postgis-users] Help with query
> I'm going to assume your table has 2 fields
> ignition_on which is a boolean
> actiontime which is a timestamp
> and your table is called ignition_log
> I would try the following - haven't tested it so don't know if it
> will work
> SELECT igoff.actiontime as ignition_off_time, MIN(igon.actiontime)
> as ignition_on_time,  MIN(igon.actiontime) - igoff.actiontime as
> igdifference
> FROM ignition_log igoff INNER JOIN ignition_log igon
>         ON igoff.actiontime < igon.actiontime AND igoff.ignition_on
> = false AND igon.ignition_on = true
> GROUP BY igoff.actiontime
> users-bounces at postgis.refractions.net] On Behalf Of Pedro Doria
> Meunier
> Sent: Friday, November 03, 2006 2:31 PM
> To: 'PostGIS Users Discussion'
> Subject: [postgis-users] Help with query
> This is probably not the best place to be asking such a (lame)
> question but perhaps someone is gracious enough to lend me a hand… ;-)
> I have the following setup in a table:
> The first record which is to be found (ok easy enough :D) with a
> timestamp meets a certain condition (ignition off)
> The following record is for the event of ignition on again with a
> timestamp.
> So the question here is: how can I compute the time difference
> between these two records in a single query?
> Better yet: finding all the records that meet the first condition
> (ignition off) and the immediately following records as to compute
> the time difference. ;-)
> Thanks in advance!
> Pedro Doria Meunier
> ICQ - 308-182-126
> Skype: pdoriam
> The substance of this message, including any attachments, may be
> confidential, legally
> privileged and/or exempt from disclosure pursuant to Massachusetts
> law. It is intended
> solely for the addressee. If you received this in error, please
> contact the sender and
> delete the material from any computer.
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20061103/f1076b85/attachment.html>
