[postgis-users] Help with query
Obe, Regina robe.dnd at cityofboston.gov
Mon Nov 6 06:44:59 PST 2006
Thanks,
That means a lot to me coming from you.  I think I cheated though -
since I'm sure I've seen that trick before.
One thing I love about SQL is that you can do so much with it with such
little code.  The trick  is to
state the problem in the shortest possible way you can and your
statement is the answer.
In this case
Give me all the ignition records that are off.
For each off record give me the minimum on record that is still greater
than my off.
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Paul
Ramsey
Sent: Friday, November 03, 2006 8:03 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Help with query
Ye gods, Regina, you're amazing.
On 3-Nov-06, at 2:14 PM, Pedro Doria Meunier wrote:
	Regina,
	You're absolutely the GREATEST! It worked like a charm!
	Thank you VERY much!
	All the best,
	Pedro Doria Meunier
	(351) 91 302 49 72 - (351) 96 247 99 12
	MSN - pdoriam at hotmail.com
	ICQ - 308-182-126
	Skype: pdoriam
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Obe,
Regina
	Sent: sexta-feira, 3 de Novembro de 2006 21:04
	Subject: RE: [postgis-users] Help with query
	I'm going to assume your table has 2 fields
	ignition_on which is a boolean
	actiontime which is a timestamp
	and your table is called ignition_log
	I would try the following - haven't tested it so don't know if
it will work
	SELECT igoff.actiontime as ignition_off_time,
MIN(igon.actiontime) as ignition_on_time,  MIN(igon.actiontime) -
igoff.actiontime as igdifference
	FROM ignition_log igoff INNER JOIN ignition_log igon
	        ON igoff.actiontime < igon.actiontime AND
igoff.ignition_on = false AND igon.ignition_on = true
	GROUP BY igoff.actiontime
Pedro Doria Meunier
	Sent: Friday, November 03, 2006 2:31 PM
	To: 'PostGIS Users Discussion'
	Subject: [postgis-users] Help with query
	This is probably not the best place to be asking such a (lame)
question but perhaps someone is gracious enough to lend me a hand... ;-)
	I have the following setup in a table:
	The first record which is to be found (ok easy enough :D) with a
timestamp meets a certain condition (ignition off)
	The following record is for the event of ignition on again with
a timestamp.
	So the question here is: how can I compute the time difference
between these two records in a single query?
	Better yet: finding all the records that meet the first
condition (ignition off) and the immediately following records as to
compute the time difference. ;-)
	Thanks in advance!
	Pedro Doria Meunier
	ICQ - 308-182-126
	Skype: pdoriam
	The substance of this message, including any attachments, may be
	confidential, legally
	privileged and/or exempt from disclosure pursuant to
Massachusetts
	law. It is intended
	solely for the addressee. If you received this in error, please
	contact the sender and
	delete the material from any computer.
	postgis-users mailing list
	postgis-users at postgis.refractions.net
	http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20061106/ad3c0ad0/attachment.html>
