[postgis-users] Correct dump and restore
Stefan Schwarzer stefan.schwarzer at grid.unep.ch
Sun Nov 12 22:59:14 PST 2006
Thanks for the suggestions.
The pg_dump works.
For the _restore I had to download the latest source package. But
because I don't do any compilations/makes I just accessed the files
in the download directory.
So if I run the below mentioned postgis_restore.pl command I get the
following error:
dyld: Library not loaded: /usr/local/pgsql/lib/libpq.3.dylib
   Referenced from: /usr/local/bin/pg_restore
   Reason: image not found
pg_restore call failed
There is a copy of that file on my computer under /Library/PHP4/lib/
libpq.3.dylib.
I tried to do a link: libpq.3.dylib -> /Library/PHP4/lib/libpq.3.dylib
But still it doesn't work.
However there is a file libpq.4.1.dylib in /usr/local/pgsql/lib
Gush, why are things always so complicated?
Thanks for any help!
Stefan
> * Stefan Schwarzer <stefan.schwarzer at grid.unep.ch> [061110 15:55]:
>> Under "Hard upgrade" I don't find anything. I guess you mean this
>> section (page 5)? Seems still rather complicated....
> I think strk was talking about the online Doku:
> http://postgis.refractions.net/docs/ch02.html#upgrading
> Essentially it is
> $ pg_dump -Fc olddb olddb.dump
> and
> $ sh utils/postgis_restore.pl lwpostgis.sql newdb olddb.dump >
> restore.log
> The rest are checks and cleanups if migration from older postgresql
> versions -  which isn't the case in your situation.
> Regards,
>         Frank
> Frank Koormann
> <frank.koormann at intevation.de>
>  Professional Service around Free Software       (http://
> intevation.net/)
>  FreeGIS Project                                 (http://freegis.org/)
>  PostGIS Support     (http://intevation.de/services/gis/
> postgis.en.html)
> postgis-users mailing list
