[postgis-users] Probelm with postgis-pg81-setup-1.1.6-1 in XP
Jan Syryn jan.syryn at trasys.be
Tue Nov 14 01:58:21 PST 2006
I had the same problem.
I wanted to upgrade the Postgis install on WinXP.
So I removed the postgis installation out of postgressql by the postgres
installer.
And indeed when re-installing postgis it generates errors.
(Eventhough the postgres installer shows postgis is not installed (anymore))
The only thing I could do (without loosing too much time over this) is
unstalling postgres, reinstall it without postgis and do the postgis install
separately.
HIH, Jan
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Tomas
Lanczos
Sent: mardi 14 novembre 2006 10:35
To: 'PostGIS Users Discussion'
Subject: RE: [postgis-users] Probelm with postgis-pg81-setup-1.1.6-1 in XP
Hi Mark,
thanks for Your answer
> Hi Tomas,
> It sounds as if you didn't remove the version of PostGIS supplied by
> the PostgreSQL 8.1 installer before running the standalone installer
> from the Refractions website (this is mentioned at the top of the
> Windows download page in the section marked "Important"), but it's
> difficult to tell without the error log.
Yes of course, it was the first I did!
> For peace of mind, it may be worth uninstalling PostGIS from the
> PostgreSQL installer and the 1.1.6 installer, and then reinstalling
> just the 1.1.6 installer (you will get a warning about the template
> database already existing but it should be safe to ignore it).
I did it before I wrote this mail, at least twice. At the moment, when I run
the Postgresql installer it shows that the Postgis is not installed. How can
I check what version of Postgis I have?
Thanks
Tomas
> Kind regards,
> Mark.
> postgis-users mailing list
