[postgis-users] Probelm with postgis-pg81-setup-1.1.6-1 in XP
Mark Cave-Ayland mark.cave-ayland at ilande.co.uk
Tue Nov 14 02:11:35 PST 2006
>> For peace of mind, it may be worth uninstalling PostGIS from
>> the PostgreSQL installer and the 1.1.6 installer, and then
>> reinstalling just the 1.1.6 installer (you will get a warning
>> about the template database already existing but it should be
>> safe to ignore it).
> I did it before I wrote this mail, at least twice. At the moment, when I
> run
> the Postgresql installer it shows that the Postgis is not installed. How
> can
> I check what version of Postgis I have?
> Thanks
> Tomas
Hi Tomas,
The easiest way to determine the current version is to issue a simple
SELECT postgis_full_version() in psql or pgAdmin.
Kind regards,
Mark.
