[postgis-users] Converting From MULTILINESTRINGM to MULTILINESTRING
Thomas Zuberbuehler tzuberbuehler at datacomm.ch
Wed Nov 15 13:48:18 PST 2006
Hi Craig
Hi Strk
Unfortunately this are data from a government authority, that I
receive for my thesis (diploma) at the university. Sorry, I became
gladly, but it's not legal in this case. I hope you have
I've got a error like this:
ERROR: new row for relation "routes" violates check constraint
I found some solution in the meantime:
select AddGeometryColumn('','routes','the_geom2','21781','MULTILINESTRING', 2);
update routes set the_geom2 = force_2d(the_geom);
alter table routes drop column the_geom;
Thank you.
2006/11/15, strk at refractions.net <strk at refractions.net>:
> On Wed, Nov 15, 2006 at 10:10:49PM +0100, Thomas Zuberbuehler wrote:
> > I have the exact similar problem. How did you found a solution? The
> > force_2d operation,  which is in the mailinglist suggested, functioned
> > unfortunately not.
> Do you have a testcase to support this statement ?
> I'd add to the regress tests if so.
> --strk;
> postgis-users mailing list
Thomas Zuberbuehler
