[postgis-users] Re: POLYGON from MULTIPOLYGON
Paul Ramsey pramsey at refractions.net
Thu Nov 16 14:28:04 PST 2006
None of the above. The fastest way is to use
encode(asbinary(the_geom),'base64')
when pulling the geometry, use Java's own base64 decoder and then the
JTS WKB reader.
Paul
Dylan Lorimer wrote:
> Thanks Paul!
> Last followup question:
> Do you think, in your experience, that it is faster to go from PostGIS
> to JTS object via:
> 1) casting binary PostGIS object to  PGgeometr and then parsing it to
> create a JTS object
> 2) Using the JTS WKT Reader on the AsText(...) from the Spatial SQL?
> Cheers,
> -dylan
> postgis-users mailing list
